Go Back   HeliFreak > R/C Helicopter Support > Beam
Beam Beam Helicopters Factory Support Forum
Old 12-07-2014, 11:57 AM   #1
trillian
Default Low headspeed on Avantgarde, just thinking
I just saw a video of a guy flying a Compass 6HV at 1200 rpm headspeed for 12 minutes and it got me thinking, I might try setting mine up as a 6s low headspeed heli.
The reasoning is this: If I gear for 6s I know it won't have the power of 12s, hence the low headspeed idea. But it would enable me to share packs with the bigger helis, which means I can charge the same group of packs (mostly 4000mah, a few 5000s and a pair of 3500s) and have an alternative heli I can fly without needing a whole other batch of packs charged.
I don't know, I'm just thinking out loud.
2009 TDR, Compass Knight 3D, Kasama Dune and Faifa
Robbe Futura SE and Dyna-X, Minicopter Triabolo 700, RMJ Raptor gasser
Beam E4 and Avantgarde, JR E8 leggero, Suzi Laos
trillian is offline        Reply With Quote
Old 12-09-2014, 06:14 AM   #2
BeamHangar
Sounds like an IDEAL project now your running the tri-blade head. More efficiency of lift on the lower head speed should also give better flight times. I may have to rethink my set-up before final configuration myself.
If ya do it, keep in touch and let us know your results? Perhaps a comparison between the 2 and 3 blade heads as well?
I had been thinking this too, just for the sake of sharing packs with my eventual Archon 500 purchase as well (but have a 12S motor atm still needing to get an ESC so can easily change my mind).
Cheers
BH
[Beam E6 AvantGarde],[Reserved for Beam E5 Archon],[Beam E4 V2 Advance & SE(x3)](Basher, Stretch, Fuselage),
[Blade mCPx V2 & Mod BL x3],[Blade Nano CPx x2],[Blade Nano Qx quad x3],[WLToys V222 quad w/Camera] Me "Flying"...>>>
BeamHangar is offline        Reply With Quote
