Go Back   HeliFreak > R/C Helicopters > Aerial Videography and Photography > FPV and Real time Video
FPV and Real time Video Discussions of receiving video in realtime from the aircraft
Old 11-12-2015, 06:16 PM   #1
Bostonewbie
Default Ham license????
What ham license would I need to operate a long range FPV system legally in the US ?
Thank you for reading
if i could only learn to type proppa..
Bostonewbie is offline        Reply With Quote
Old 11-12-2015, 06:22 PM   #2
Mattinfla
A Technician class license would cover anything you need for FPV.
Goblins - 380, 500, 700
BK Servos, Spartan vx1e FBL units, Switch Blades
Jeti DS-16
TORCHS member, AMA 64878, Citizen 690
Mattinfla is offline        Reply With Quote
Old 11-12-2015, 08:24 PM   #3
Bostonewbie
Thank you for the reply, I just found this site.
http://www.hamradiolicenseexam.com/?...FZI9gQodpOUPtw
Old 11-12-2015, 08:29 PM   #4
Fauropitotto
Also this: http://www.arrl.org/chpt-1-introduction
Fauropitotto is offline        Reply With Quote
Old 11-28-2015, 05:46 PM   #5
JCLs
I found several free apps for doing this. I thought the AARL book and disc were not worth the money, BUT I have EE degree so that part was easy.
AMA 954079. KG5BBF
JCLs is offline        Reply With Quote
Old 01-26-2016, 10:51 PM   #6
bluecrackers
Is there anywhere to read up on the rules for this? I talked to a friend and he said something like over 5 watts would require a licence? These are rated in milliwatts, like 600mw?
bluecrackers is offline        Reply With Quote
Old 01-27-2016, 04:23 PM   #7
Danq0
If that is the case, using a 600mw vtx will not require a hamm license. 1000mw is equal to 1 watt.
Danq0 is offline        Reply With Quote
Old 01-27-2016, 08:32 PM   #8
Mattinfla
IIRC, the power limit without a license is 25mw.
Jeti DS-16
Old 05-09-2016, 05:31 PM   #9
JCLs
Not for all frequencies being used!
AMA 954079. KG5BBF
