Go Back   HeliFreak > R/C Helicopters > Speed Helicopters
Speed Helicopters Speed Helicopters. Any brand as long as it goes FASSSSSSSSSTTTTTT!
Old 12-11-2015, 07:21 PM   #1
majorlemond
Default Newbie - First "speed" heli Goblin 500! :)
I'm more of a dirty 3D guy, but I recently put a KDE 550xf motor in my goblin 500 (4.5kW) as an upgrade to the stock motor.
I must say that I know basically nothing about speed helis.... But,
I have to say I'm pretty impressed with how fast it goes, and I didn't realize how much fun doing speed runs in it could be
Now I'm thinking "how can I make it go faster?"
In a snap shot my setup is:
Goblin 500
Sk540
Rail 516mm mains (current setup 12 degrees pitch @ 2500 in IU2)
Edge 86mm tails
Yep 120a LV speedie. (Using sk540 governor though)
Kde 550xf G3 1200kv
Gens ace 4400mah 65c 6s
Not looking to break records, I just want to push it!
majorlemond is offline        Reply With Quote
Old 12-12-2015, 04:12 AM   #2
Thunder Fighter
Probably 3 main things will have the most impact on the speed with your setup:
Practice
Increase Pitch
Increase Headspeed
Start increasing your pitch and headspeed but keep an eye on your ESC and packs as they will be the weak points in the setup.
I have run my G500 is speed comps and for the 500-550 class it was a great option.
//Dennis.
SOXOS DB7 : SOXOS 550 : SOXOS F3C : Protos Max V2 stretch 800 : Protos 380
SAB Goblin 700 nightflyer : Jeti DS-16 : Mini Protos FBL Stretch : Logo 600
www.soxosaustralia.com.au
Thunder Fighter is online now        Reply With Quote
Old 12-12-2015, 07:56 AM   #3
KiloXray
http://helifreak.com/showthread.php?t=714548
Prtos Max 806-- Prtos 380 -- Prtos 380 Speed -- Jeti DS14
MSH USA - Brain Test - Xpert Servos - Lynx
RCHN Citizen № 268
KiloXray is online now        Reply With Quote
Old 12-31-2015, 03:57 PM   #4
Airboss
OC Helifreak
you also have to learn not to lose energy in turns and practice "split S" or other variations
My Urukay with the HPS3 blade gets 80-100mph very easily
Edge540V3 DA120
Urukay HPS3
KSE700 HPS3
Mamba DA70
Airboss is offline        Reply With Quote
Old 01-05-2016, 11:22 PM   #5
ian.newson
Honestly I'm a little surprised by that. My 630C gets over 80mph without any concern for technique.
FOR NO FREE APE DIES
Gaui X3/Gaui X5/Goblin 570 KSE/Goblin 630C/Thunder Tiger Raptor 50
Citizen 717
ian.newson is online now        Reply With Quote
Old 01-06-2016, 11:40 AM   #6
Airboss
OC Helifreak
wonderfull
Edge540V3 DA120
Urukay HPS3
KSE700 HPS3
Mamba DA70
Old 01-08-2016, 12:04 PM   #7
Ninealign
X speed blades, more pitch, more headspeed. You've got good stuff in there for speed.
Ninealign is offline        Reply With Quote
Old 01-08-2016, 12:09 PM   #8
Justin Pucci
Please do not increase pitch before first CG'ing the model correctly, increasing headspeed and then getting your technique nailed down. Otherwise, you're in danger of pitch-ups due to retreating blade stall.
See a detailed explanation in the link that KiloXray provided above.
For the Goblin 500, you should be looking at 2800-3200 with 12-13 degrees of pitch and a nose-down CG of approximately 10-15 degrees. Also, drop your tail blade size down to 70-75mm for less tail power loss in your runs. That combined with proper technique will get you average speeds in the range of 100-115mph.
Once you've got that down and are comfortable, you can move up to 14+ degrees of collective.
Good luck and keep us posted on your progress!
Cheers,
- Justin
Justin Pucci is offline        Reply With Quote
Old 11-14-2016, 01:38 PM   #9
slikwrik
majorlemond, how is your speed G500 going? Have you enjoyed it?
Trying to retrofit one of my own into a lean mean G500 speed machine
slikwrik is offline        Reply With Quote
