Go Back   HeliFreak > R/C Helicopters > Aerial Videography and Photography > FPV and Real time Video
FPV and Real time Video Discussions of receiving video in realtime from the aircraft
Old 12-28-2015, 08:30 PM   #1
dexterous
Default My FatShark Trinity Head Tracking & Spektrum DX9 How-To video
Guys,
After having a hard time finding this info, I decided to create a video detailing how to get the FatShark Trinity head tracker working with new generation Spektrum radios. I hope this helps someone in the future:
DX9, 600x, 500x, 450x, 300cfx, and a nano CP Xs or two (plus the stuff I have hidden from my wife...)
dexterous is offline        Reply With Quote
Old 12-31-2015, 12:03 AM   #2
Tempe
Ironically i was trying to figure this same setup out when you posted this vid. I have a couple questions. My Dx9 doesn't give me the option to set AUX4 to channel 9. I'm trying to do this to get my "roll" function working. Also i can't seem to get anything other than "pan" to work and most of the time it's not when I'm panning the goggles meaning that if i "roll" the goggles, the pan will function. is there a way to determine which plug goes to which aux port on my receiver? Thanks
Ian
Tempe is offline        Reply With Quote
Old 01-01-2016, 08:43 AM   #3
dexterous
First, do you have the three axis gimbal or the two axis gimbal? I will try to make a second video for a three axis gimbal soon.
As best as I can tell, you can only setup the head tracking system on channels 6, 7 and 8. If you need channel 9 to work, you're going to need to modify the radio programming so that one of the aircraft control channels is relocated to channel 9 (AUX4).
Also, it sounds like you didn't go into the beep code driven setup menu on the trinity head fracker and configure things. If you did, you have a mismatch and you're sending the signals on the wrong channel.
