Go Back   HeliFreak > R/C Helicopters > Helicopter Safety
Helicopter Safety R/C Helicopter Safety
View Poll Results: would you fly these blades?
Yes, no problem 7 16.67%
Yes, if i perfomed a good inspection first 4 9.52%
No, probbly not worth it 14 33.33%
Hell no 17 40.48%
Voters: 42. You may not vote on this poll
Old 06-05-2016, 03:42 PM   #1
HELI_FUN
Default To fly or not to fly, on these blades...
would you fly on these blades or not worth it?
one blade has a few surface cracks around the mounting bushing in the blade. here are a few pictures.
https://flic.kr/s/aHskAsGBhE
CLICK FOR MORE DETAILED PHOTOS ^
HELI_FUN is offline        Reply With Quote
Old 06-06-2016, 01:02 PM   #2
HELI_FUN
wow 46 views and only few votes.
It looks like people going more to the don't fly them side then anything else. time for some new blades. is 60 bucks a good deal on some halo blades 700mm
Old 06-06-2016, 01:28 PM   #3
Dylan Hudock
I would definitely not fly those. You are not sure how deep those cracks go, and if the blade is weakened structurally. And yes, I would say 60 bucks is a good deal.
KBDD Team Pilot Trex 700-500-450, Gaui X3
Dylan Hudock is offline        Reply With Quote
Old 06-06-2016, 02:19 PM   #4
HELI_FUN
Default thank you :)
Thanks for the input, I have a guy at my local R/C shop that wants to sell me his old halo blades, so i will most likely pick those up and feel more safe when i go to spool this thing up for the first time.
better to be safe , then sorry
Old 06-06-2016, 03:03 PM   #5
Epoweredrc
you didn't say what size they are but even $100 i know sucks but its worth that to be safe. most 325/425 blades are pretty cheap
XK252,K120,Cpx450 ZYX,,Trex600 Beastx, Gremlin,POD Racer, GLH,Whipit,Z-84, Elelctric Shock AMA 27 yrs.
Epoweredrc is offline        Reply With Quote
Old 06-06-2016, 06:24 PM   #6
HELI_FUN
700MM HALO blades. I also have more pictures of them in the link above the small photo.
they look dam perfect other then the spider crack around the mount hole. oh well good to share with others
Old 06-06-2016, 06:49 PM   #7
Epoweredrc
Oh, I didn't click the link sorry. ouch... well those are not cheap. what happened to them to get that way? did you crash or bad landing?
Old 06-06-2016, 07:04 PM   #8
HELI_FUN
No, I have not even got to fly the dam thing yet, taking things very slow and checking everything on it. I bought it used on ebay for 500 bucks and it came this way. the guy said to check the blades before flight...
I have my 300 CFX I've crashed at least 10 times now to keep me busy till i get this one working.
Are the blades that i have all carbon fiber or just on the part that says 3d? they feel very heavy but they are the only blades i have handled in 700 mm size so i don't know the difference.
i checked on-line and the halo blades my r/c shop guy wants to sell me go for around $128 new, so sounds good to me.
Old 06-06-2016, 07:07 PM   #9
Epoweredrc
Oh man that stinks, sorry to hear that... I just clicked the link and those blades are cheap, some have been happy with them, some have not.
they should be carbon fiber. but again cheaper blades
Old 06-06-2016, 07:12 PM   #10
HELI_FUN
Thanks for you help man. one last question have you flow halo blades before ? do you like or dislike them?
when you said the blades are cheap you were referring to the pro 3d blades correct?
Old 06-06-2016, 07:41 PM   #11
Epoweredrc
i never tried Halo blades, and yes the pro 3d are cheap blades.
I have flown Zeal, Revolution, align , thunder power, Rails.
i am not that great of a pilot so they all fly well. I do think the Rails are quieter and might be a little more stable.
Old 06-08-2016, 12:50 PM   #12
HELI_FUN
Default New blades
Thanks for all the input guys, ended up just getting a new set of 700 mm blades. After checking them out found my old blades must have been 710 mm you can also see they are a bit bigger and have a different cg when hanging by mounting hole.
ID:	656295   Click image for larger version
ID:	656296   Click image for larger version
ID:	656297   Click image for larger version
ID:	656298   Click image for larger version
ID:	656300   Click image for larger version
