Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 06-06-2016, 10:41 PM   #1
TTboy53
Default Rail 606's
What's the general opinion of these?
Raptor 50 se w/ Os 55/ Outrage flybarless
Dromida vista fpv
TTboy53 is offline        Reply With Quote
Old 06-06-2016, 11:01 PM   #2
dominator
good all around blade. They have a pretty wide chord but if your flying them on a nitro using a os55, Id go with a lighter weight blade. It will help alot with motor bogging.
Team Compass
Cool Power fuel
dominator is offline        Reply With Quote
Old 06-07-2016, 09:38 AM   #3
LoveToFly1
I love mine on my N5C with an OS55 in it. I don't even fly 30%, I fly 22.5% in it and it handles them very well.
they are good blades. they smack well, and also do very precise flying, along with big huge big air and still track. they are not very loud, the tip of these blades is designed to be efficient, not loud. if its noise you are after, then I would go a different route, but if its performance you are after, I don't think they can be beaten at all.....
Gasser Mike
Team Synergy, Team KDE Direct, Rail Blades, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote
Old 06-08-2016, 07:47 AM   #4
TTboy53
Thx . I've give 'em a try. Gotta be better than the original Tt normal blades.
Dromida vista fpv
Old 06-18-2016, 07:14 PM   #5
Dennis P
Probably the most commonly run blade on 600 nitros out there today. Plus easily available in Canada.
Team Renegade R/C Heli Flyers
Dennis P is offline        Reply With Quote
Old 06-18-2016, 11:22 PM   #6
Epoweredrc
I never even thought about the larger blades being for Nitro VS electric. so no one with 600 electrics use them?
XK252,K120,Cpx450 ZYX,,Trex600 Beastx, Gremlin,POD Racer, GLH,Whipit,Z-84, Elelctric Shock AMA 27 yrs.
Epoweredrc is offline        Reply With Quote
Old 06-19-2016, 11:11 AM   #7
Dennis P
The Rail 606 is used on electrics and nitro Helis . It is an excellent blade for either but we must understand that a nitro will not run the pitch and rpm that many today run on the higher powered electrics.
