Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 08-08-2016, 06:46 PM   #61
yakky
Originally Posted by Number View Post
Yeah, as okay as it looks, I'm willing to bet the Gaui X3 stretch will be Twice the heli as this.
Do you have a reason you suspect that our are you just a fanboy?
Helibargains.com Heli Only Deal Site
yakky is offline        Reply With Quote
Old 08-08-2016, 06:58 PM   #62
Number
If the shafts and boom are the same size as all the other 450 Aligns, that's more than reason enough.
Number is online now        Reply With Quote
Old 08-08-2016, 07:05 PM   #63
Sirolf
I bet it will be. I am not saying a 5mm spindle won't bend like a 4mm one but it will def stronger. You don't know how many spindles i had to change from very minor crashes.
KDS Chase 360 - BeastX Scorp HK2520-1880kV
Align Trex 600NSP DFC - BeastX - 91HZ-R CentreGlide
Align Trex 700E DFC - BeastX - Scorp HK4530-500kV
Sirolf is online now        Reply With Quote
Old 08-08-2016, 07:21 PM   #64
Number
Yupp, in almost 3 years of owning my X3 and literally countless crashes, I never bent a main or spindle shaft. That includes when my X3 exploded due to a shitty Lynx blade departing the blade grip...
Old 08-09-2016, 01:40 AM   #65
Trexwilly
The picture with the speed shroud on the tail boom looks super fugly to me!
Seems Align might feel the sway of market demand! I have to lmao watching over the 450 market since 2007, and the whole market demanded TT, and now they are back to wanting belts!
I will state that the older Align belt system was terrible, small pulleys and bad ratios. I would call this more of a Logo design than Protos, the uni-belt has it's weakness too. To me, this over main gear large diameter pulley is the way to go!
As far as shafts go, Align will do themselves a disservice if they try and use the Pro stock stuff... But we'll need to wait I guess, to see which route they go there.
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote
Old 08-09-2016, 08:12 PM   #66
RC/DC_5000
Yea I wouldn't mind seeing Align fatten up the shafts. It's not looking good though. The bearing block and the rotor housing look like the same parts on the 450L and Pro. That might be part of their crash repair business model. Cut into their profits.
Bigger shafts are for crashing... not performance though. That's a questionable need.
Definitely agree that Align still screwed up the 450 speed fuselage. They just refuse to get the proportions correct. Make it look like the 700... but smaller. It's not that hard. They always make the boom too wide and bulky... like a boat. It looks ridiculous. Again. Probably still ruins the COG.
RC/DC_5000 is offline        Reply With Quote
Old 08-10-2016, 08:05 AM   #67
johnniechang
From what I've heard here in Taiwan the main and spindle shafts will be 1mm thicker than previous.
johnniechang is offline        Reply With Quote
Old 08-10-2016, 03:01 PM   #68
Trexwilly
I will likely try the Protos 380 rather than the 480L if they have not changed much other than the boom and added a belt the the Align.
After having had a large cross section of the last generation of "450s" that were stretched to 360s, I like the look of the changes they have instituted to that model, two belts, bit like the Goblin, but option to do a proper CF tail, or stick with a AU boom.
I am in no hurry to try a 380, just kicking tires right now, so I will wait and see what Align has done. I do like my 450L, but I have to take into account, crashing is part of flying for me. Once I get comfortable, I start to get low and stupid, cause it's part of the fun
I know some people like the "all in one box" that Align offer, but I typically don't like all of their stuff, and throw much of it away. That's not to say it isn't fine, it's just not for me. I have had great luck with their motors! But I like different FBL controllers, servos, and ESCs.
Old 08-10-2016, 03:28 PM   #69
yakky
Well, they do seem to be offering a lot of kits that are frame, blades and motor, which is what I really like. Let me pick servos and FBL.
Old 08-10-2016, 03:35 PM   #70
Trexwilly
Yup, I have a 700L and I did use their servos, and they seem pretty good, but on the 450Pro and 500s I used their servos and ESCs, I was disappointed to be sure! The stuff worked, but once I tried some other "aftermarket" goodies instead, it was brought to light that I preferred those results.
My 405L I got the yellow box kit, it had the wider BB, blades, and motor, great value!
Old 08-12-2016, 09:59 AM   #71
nynextel88
Full specs and pictures of the new 470LM
https://www.facebook.com/media/set/?...3419543&type=3
nynextel88 is offline        Reply With Quote
Old 08-12-2016, 10:20 AM   #72
Number
Ahh yes, they finally fixed the tiny butter shafts.
Nice electronics too. But WHY the hell did they not put a HobbyWing
Old 08-12-2016, 10:55 AM   #73
jorgeurizar
Really like the specs! Looks like it will be a great heli.
jorgeurizar is offline        Reply With Quote
Old 08-12-2016, 11:08 AM   #74
nynextel88
Yep should be a fun little bird. I know a lot of people did not like TT on this size as it was easy to strip the gears, the belt should work much better for this size.
Old 08-12-2016, 11:22 AM   #75
corywrx
I want one
V977, Gaui X3 (Brain) | Futaba 10J | Citizen 799
RCHN Listener Chat (Discord) - https://discord.gg/6SvCccC
corywrx is online now        Reply With Quote
Old 08-12-2016, 12:04 PM   #76
NC_2_VA
So the "M" is for metal edition. Will there be a light weight plastic edition?
Grand RC
Citizen 242
NC_2_VA is offline        Reply With Quote
Old 08-12-2016, 12:18 PM   #77
yakky
When do pre-orders start? I see them for the new 700....
Old 08-12-2016, 12:37 PM   #78
Number
Well I mean, the 700X was announced a couple weeks ago... this, just today...
Old 08-12-2016, 01:29 PM   #79
Trexwilly
Hey Keith how come you changed your account? What happened to Bladescraper?
Old 08-12-2016, 01:30 PM   #80
yakky
Yep, and the pre-orders started that same day at Amain IIRC.
