Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 01-05-2017, 02:22 PM   #941
Andy from Sandy
Hmm, I wonder how much the bundle of wire weighs at the back of my NEO? If I shortened them it would make for a very tidy build.
Andy from Sandy is offline        Reply With Quote
Old 01-05-2017, 02:57 PM   #942
yakky
It does make it look clean, but IMO the weight is negligible. Then if you ever want to sell your servos, good luck! I prefer to fold the wire over itself and cover it with wire loom.
Helibargains.com Heli Only Deal Site
yakky is online now        Reply With Quote
Old 01-05-2017, 03:20 PM   #943
Number
I cant stand bundled up wires. They are ugly, take up tons of space, and are a pain to hide. Not to mention long wires increase the chances of them getting caught in something spinning.
If I ever need to sell my servos I'll open them up and solder new leads on. 5 minute process at the worst.
Number is online now        Reply With Quote
Old 01-05-2017, 06:12 PM   #944
kevindnyc
All wires should fit under the gyro plate nicely just like the 450 pro
Sent from my Moto G (4) using Tapatalk
kevindnyc is offline        Reply With Quote
Old 01-05-2017, 06:52 PM   #945
Indokast
Nice!
~ Brandon Chew ~ You best run for your life because here goes nothing! ~
Synergy E7SE/E5, Gaui X5/X3 stretch, Trex 470LM/450L/450 Pro DFC, Oxy 3 stretch, 300x/cfx, 230s, 130x, mcpx bl, K120, V977 - DX18/Jeti DS-16
Indokast is online now        Reply With Quote
Old 01-05-2017, 07:14 PM   #946
kevindnyc
As you can see in the pics I did sand the edges and will also add a few strips of electrical tape to the plate and double sided tape to the boom holder to prevent slipping.
D420, Align 470, Align 450pro v2
Old 01-05-2017, 08:03 PM   #947
Number
I tried but between the S.Bus cable and RPM sensor and all the servos there was no way they'd all fit with them folded up.
Old 01-05-2017, 08:28 PM   #948
gimbleguy
yep I can imagine, talking about LP, I got an LP on it's way from my LHS >-<
Slow and Steady FTW.
gimbleguy is offline        Reply With Quote
Old 01-05-2017, 10:17 PM   #949
gimbleguy
Old 01-06-2017, 04:45 AM   #950
Andy from Sandy
It will be interesting to see what you get in the box. There appears to have been quite a number of changes.
As for wiring I have mine neat as I have shown elsewhere. It was more a rhetorical question about how many grams could I shave off the model by removing anything not required.
Old 01-06-2017, 04:55 AM   #951
Necroscope
I have run double sided tape on the inside of the frame for my 450 and 550 and then run the servo wires on the tape. Seems to be working ok.
I have been thinking about getting some of servo wire organizer stips and see how they work.
Probably a bit big for a 450, but may be ok for a 470 and bigger.
http://www.espritmodel.com/bvm-servo...-strips-6.aspx
Bob1 6s with SK-720BE & GPS-1.
Bob 2 with SK-720BE
Bob 3 with SK-720BE & GPS-1.
Jeti DS-16. Whovian.
Necroscope is offline        Reply With Quote
Old 01-06-2017, 05:05 AM   #952
Andy from Sandy
For the esc lead I used shoe goo to hold it against the inside of the frame. Similar, seems to be working ok.
Old 01-06-2017, 01:52 PM   #953
volumax
Originally Posted by Delfin View Post
Just received my 470LP kit. How many hours does it take from build, setup & maiden? Will the red metal frame stiffener from the 450L fit? The landing gear fits perfect on the 450L.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Yes the red stiffener is the same for the 470L and 450L.
Align Field Representative
volumax is offline        Reply With Quote
Old 01-09-2017, 12:54 AM   #954
blade_crasher
Default Battery space
I don't own one of these birds, but am interested.
I have some 6S packs that I wonder if they would fit in the space provided. They are 115mm x 35mm x 48mm. Is there enough width or height to allow that 48mm dimension?
Gaui Hurricane Spirit Pro | 450Pro 360mm (belt stretch) Spirit 4S | 180cfx | DX8
blade_crasher is offline        Reply With Quote
Old 01-09-2017, 05:45 PM   #955
dannym
The width and length should not be a problem, but the 48mm height could be a problem. If thin two way tape is used to attach the battery to the battery plate, it might fit. With that big of a battery you will have a difficult time getting the CG correct. I am running 1800 batteries and have to move them in quite a bit to get the CG spot on. That size sounds like a 2600 and would be considerably heavier.
470LM HW Platinum Pro 60A, Mini VBar
450L
HW Platinum Pro 50A, Mini VBar
dannym is offline        Reply With Quote
Old 01-09-2017, 06:54 PM   #956
perrypoint
Not on mine. My 470LM kit would be pinching even a single-layer pretty hard, doubling up or overlapping any wires would be impossible. Even if I fed the connectors through before putting the plate in place it would be too tight for that option.
perrypoint is online now        Reply With Quote
Old 01-09-2017, 10:03 PM   #957
HeliLust
On mine I ended up pulling all the slack to the the front cross member just behind the motor and zip tieing it to the cross member folded up neatly. I like my servo ports facing the front so there not a rats nest of wires hanging out the back. I wish they would change the orientation of the rudder servo or make the wire exit the other side of the case. Nasty wiring is a pet peeve of mine, I like it neat and hidden.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 700N
Team Align Enterprise Hobby Facebook Align Part Finder
HeliLust is online now        Reply With Quote
Old 01-10-2017, 10:57 AM   #958
blade_crasher
Thanks for the details. They are 2150 size but their 48mm dimension does make fitting a challenge.
Old 01-10-2017, 11:06 AM   #959
yakky
Just go for it. The devil sitting on your shoulder said they'd probably fit, and anyways if they don't you can get slightly packs that will fit the other heli.
Old 01-16-2017, 03:06 AM   #960
Heliyogi
Default 470LP
Hi guys, can you all please point me out to a good building blog/video I'm about to start putting together my bird.
Thanks!
Heliyogi is offline        Reply With Quote
