Go Back   HeliFreak > R/C Helicopters > Aerodynamics, Physics and Engineering
Aerodynamics, Physics and Engineering Aerodynamics, Physics and Engineering Discussions
Old 07-08-2016, 11:20 PM   #1
1BOHO
Default Is a well designed coaxial heli at any disadvantage in speed or maneuverability to a
...non coaxial one?
I ask because to date of at least what is not classified isn't this the fastest and most maneuverable helicopter in the world?
The Sikorsky S-97
ID:	661073   Click image for larger version
You know you are not welcomed at a snooty country club when you jump in the pool and everyone else jumps out....
1BOHO is offline        Reply With Quote
Old 07-18-2016, 10:57 PM   #2
megawhacker
I do not know the answer to your question, but the photo you post is of a helicopter with a pusher prop. I will suggest that any aircraft with a pusher prop is not relevant to your which is faster question.
HELIFREAK-where the signal to noise ratio varies minute to minute.
Helifreak number 133542
megawhacker is online now        Reply With Quote
Old 07-26-2016, 01:25 PM   #3
R_Lefebvre
The Eurocopter X3 concept is faster.
One disadvantage of a coaxial, is the taller mast which is difficult to streamline.
-Rob
Managing Director
NOVAerial Robotics Inc.
R_Lefebvre is offline        Reply With Quote
Old 07-27-2016, 02:35 PM   #4
HeliXXL
Default Maybe
I am not an engineer so this is my opinion only. First, the X3 is only marginally faster the the S-97 ( a few kts tas) and both are compound helicopters. Of note in regard to the X-3 is that it has achieved slightly better speed and was able to do so without the active vibration control required in the sikorsky. Sikorsky has been working on speed helicopters since the X-59 but abandoned that project because of expense and high vibration at high speed. Now maneuverability is a different story. According to sikorsky the S-97 is far more maneuverable the any standard rotor helicopter currently in production. Personally I would attribute that partially to the coax and partially to its rigid rotor system. Back in the 60s lockheed worked on the AH-56 Cheyenne which was also a compound helicopter but was somewhat more traditional in its layout in that it still utilized a tail rotor but used a pusher prop and stub wings. It was extremely fast (212 kts) and was also very maneuverable because it too had a rigid rotor head in contrast to the cobra with it's semi rigid teetering rotor. Not sure if that answers your question but I hope it helps some.
P.S. I love alternative rotor designs i.e. coax flettner etc.
HeliXXL is offline        Reply With Quote
Old 11-28-2016, 11:56 PM   #5
velo24
This might explain things:
https://www.youtube.com/embed/f72WZwvMTj4
So as long as heli speed is low relative to blade speed, it doesn't matter. But yes, a coax can fly faster if given the chance.
velo24 is offline        Reply With Quote
Old 12-08-2016, 08:12 PM   #6
MotorRotor
Exactly. And with a puller or pusher prop the two rotors would only have to be set at a pitch that would maintain lift required to counter the weight and the prop can generate the speed.
Phil
MotorRotor is offline        Reply With Quote
