Go Back   HeliFreak > R/C Helicopters > CAD/CAM
CAD/CAM R/C Helicopter CAD/CAM
Old 08-26-2016, 12:04 PM   #1
The_crack_fox
Default Custom 500 heli project
Here's a pic of a heli I've been working on. Its based on a trex 500, but some elements are inspired by the gaui X5, and the belt drive and servo layout is a little bit goblin-ish. I'm going to get a friend to 3d print the first prototype parts. Side frames etc. will be lasercut aluminium. Once the design is proved I'll machine parts properly and get the frames water jet cut from carbon.
I did the render with solid works tonight
The_crack_fox is offline        Reply With Quote
Old 08-26-2016, 02:46 PM   #2
gstoneberg
Nice! Are you building everything up from scratch, or sourcing existing parts where possible?
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis
gstoneberg is offline        Reply With Quote
Old 08-26-2016, 07:44 PM   #3
The_crack_fox
I'm gonna use a lot of align parts. Shafts, 500esp tail slider, autorotate gear, dfc head. Motor/servo plate and boom holders I'll make on my cnc mill.
Old 11-10-2016, 09:35 AM   #4
The_crack_fox
http://www.helifreak.com/showthread.php?t=756104
Its finished
