Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 08-27-2016, 12:05 PM   #1
TR450ZS
Default Swash bearing replacement
I picked up a used swash plate for a trex 500 and although there is absolutely no slop in the bearing at all, it doesn't feel smooth when I rotate it.
Is it possible to disassemble the swash and replace the bearing? Has anybody done this before?
Allan
TR450ZS is online now        Reply With Quote
Old 12-08-2016, 12:07 PM   #2
zzyzx_cm
ive tried, not successfully. the top and bottom halves are threaded together. after that is taken apart you can press the bearing out the bottom. i damaged it trying to unscrew it, whatever they use to fix the pieces together works well. i don't think i tried heating it which probably would help.
zzyzx_cm is online now        Reply With Quote
