Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-30-2016, 10:55 AM   #1
TR450ZS
Default Another Align DS525M servo going bad
Last year August I decided to replace all the servos on my 500 EFL as the cyclic servos particularly had quite a lot of slop (DS510M). I was itching to go with MKS servos but felt that they were just too expensive. 82 flights later with the new servos and the new tail servo is going bad. Twice it happened now that, in flight, all is good, then when I land, hit TH and carry the heli to the bench and suddenly notice that the tail servo is not responding to gyro or stick inputs. If I nudge the tail push rod the servo jumps to life again. I did a quick search and found at least 3 other reports of this happening, apparently it is caused by the pot going bad. I have a spare ds520m that I am going to fit in its place, as I am not willing to risk an in flight failure.
Is there any sense in trying to clean the pot on this servo or should I just bin it as scrap?
Allan
TR450ZS is online now        Reply With Quote
Old 11-03-2016, 09:49 PM   #2
Dylan Hudock
I would just bin it as it is a relatively inexpensive servo. I am still using mine, but will be replacing it with a KST sometime this winter.
KBDD Team Pilot Trex 700-500-450, Gaui X3
Dylan Hudock is offline        Reply With Quote
Old 11-12-2016, 06:59 PM   #3
bad007
Me too, se my threads? 3 DS525's now and now a crash
http://www.helifreak.com/showthread.php?t=763521
http://www.helifreak.com/showthread.php?t=760707
http://www.helifreak.com/showthread.php?t=764145
Align 450Pro 3GX Edge KDBB, Align 500 DFC 3GX, Align 500L MicroBeast Plus HobbyWing Platinum Pro V4 Plus Switch Blades, KST HV Servos, Align 550 DFC MicroBeast Plus, Velocity 50 Vbar 5.3 Pro, OS55 HZ-R, Radix V2 KDBB Castle,
bad007 is offline        Reply With Quote
