Go Back   HeliFreak > R/C Helicopters > Speed Helicopters
Speed Helicopters Speed Helicopters. Any brand as long as it goes FASSSSSSSSSTTTTTT!
View Poll Results: Do you use telemetry on your Speed Heli
Yes, I always use telemetry. 29 82.86%
No, I don't have time for telemetry 4 11.43%
What is this telemetry thing you speak of??? 2 5.71%
Voters: 35. You may not vote on this poll
Old 11-17-2016, 10:40 AM   #1
iscripter
Default Do you use Telemetry
I was curious how many of us use telemetry on our speed machines. Do you feel it is a necessity or a luxury item that is not always needed. Post your thoughts.
Citizen 682 | Gaui X3-Spartan VX1n | Gaui X5-Spartan VX1e | Goblin 700 Speed-Spartan VX1n
JETI DS-14
iscripter is offline        Reply With Quote
Old 11-17-2016, 10:47 AM   #2
Ah Clem
I don't, at this point have a speed ship, but I do use JR telemetry for receiver voltage on all of my new builds and all of my older machines that I have upgraded to DMSS.
I recently installed a main pack voltage sensor on a Three-Bladed 700 (Chronos) and am interested in setting one up for RPM.
Old 11-17-2016, 03:32 PM   #3
Dansy
Absolutely on all my heli and planks....I didn't think of telemetry when I first got the JETI DC-16 3 years ago, but after trying some....it's now a must, especially high power setup, like my speed heli.
Daniel....Goblin Urukay Red/White, Gaui R5
Goblin 380 KSE Yellow/Blue, Goblin 420 XNova
Ikon2/Brain2, Axon, Kontronik, XNova, Jeti DC-24
Revolectrix DPL8, PL8, 2x XP10 and Bump Contr.
Dansy is online now        Reply With Quote
Old 11-18-2016, 05:43 AM   #4
wadders248
I swapped to Jeti at the start of this year, mainly to add telemetry for my speed helis, though I'm starting to use it on all my helis now.
For speed flying I use the alarms to let me know when I'm at a certain distance from where I'm standing and the height, so I know when to start my reversal. Once you get to know a flying field you don't need it as much, but it's great for a new environment.
Kasama UK Team Pilot | Bavarian Demon
wadders248 is online now        Reply With Quote
Old 11-18-2016, 11:27 AM   #5
iscripter
Really cool idea. So I assume you are using some type of GPS sensor to tell you the distance. And then you are setting the alarm to go off at 200 meters so you know the correct distance to start your turn around for the next pass.
Which GPS sensor are you using?
JETI DS-14
Old 11-19-2016, 06:47 AM   #6
john2kx
I switched to Jeti because of their telemetry. It took 3 years to convert all my models over and as the guys over at the Nation would say, "you just don't know what you don't know".
I also use the Power box systems GPS II to alert me I'm 200 meters out on my speed machine. Flew it for 6 months to monitor speed only and read on the forums here about setting up a distance alert. After using this feature for a while now, I have the distance nailed down and can start the turnaround without waiting for the voice alert. Another use for PBS II is if you have a target speed you are trying to achieve is set a alarm up to activate when you reach that speed, ie > 130 mph.
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is online now        Reply With Quote
Old 11-19-2016, 08:13 PM   #7
iscripter
I too am a recent convert to JETI and switched because I liked the way they have implemented telemetry. So far I am very happy with telemetry on my JETI but I am still learning their system and how it works. The MUI sensor is a awesome thing and I no longer need to fly on a timer and can land based on mAh consumed. I don't think I will ever go back to flying without telemetry
JETI DS-14
Old 11-21-2016, 03:46 AM   #8
wadders248
I'm also using the Power Box GPS II
Old 11-21-2016, 08:00 AM   #9
Dansy
JETI GPS and PowerBox GPS II
Old 11-21-2016, 08:53 AM   #10
iscripter
So of those 2 GPS systems which one do you like best? Are there any differences between the 2. Is one easier to setup than the other or are they just straight plug and play. I here the PowerBox GPS II is supposed to be more accurate. The only experience I have with GPS sensors is with my old Specktrum setup I used to have.
JETI DS-14
Old 11-21-2016, 10:38 AM   #11
Dansy
Limited used of both......didn't connect the PB GPS correctly....so I will know next time out.
The JETI one is pretty easy to use both not that accurate was installed in my pattern plane for fun about 1 year ago.....for the PB I'm only flying the g380....winter mode has started, but I will temporarily do an install and see how good it's on this small heli. The PB is for my R5.
Old 11-21-2016, 11:04 AM   #12
Justin Pucci
I do use telemetry extensively and will say that it's critical to taking your speed flying to the next level. There's only so much that can be judged visually in speed runs, so we need some extra help to really optimize technique and setup.
Current, voltage, headspeed, altitude, distance and speed telemetries tell you subtle things about each run that you'd be none the wiser to with just your eyes.
Keep in mind, that I'm not suggesting that even the casual, non-competitive speed pilot should go stock up on telemetry, but if you're trying to push the limits of the machine and your skills, then the telemetry is indispensable in determining if your thumbs and heli are working well together.
Justin Pucci is offline        Reply With Quote
Old 11-21-2016, 05:23 PM   #13
felopaul
i use futaba telemetry with goblin speed, GPS , RMP, Voltage, Curent.
felopaul is offline        Reply With Quote
Old 11-21-2016, 08:04 PM   #14
john2kx
I performed a test last year with the Jeti and Powerbox Systems GPS units mounted to a high performance glider. Hands down, the PBS system won out. It responded without delay when power was applied and did not show my aircraft doing 250 mph while going straight up. Having a Jeti TX, with both units visible on screen, it was clear who the real winner was.
They are both really easy to set up.
Old 11-24-2016, 04:29 AM   #15
weracemo
I use VControl with the Vbar NEO (telme for UI sensor) but purchased a Jeti DS16 just for the option to choose different GPS sensors if I don't like the Vbar GPS....
I really don't want to use the Jeti so any Vbar GPS feedback would be much appreciated.... eg accuracy, reliability, features
Goblins 770, (x2)700s, 630, (x2)570s, 420, 380, Comet??, TDR 2 & Trex250,,,,100%Vbar, BK, Xpert, Kontronik, Hobbywing ,,,, Czn#760
If there's a better heli I'm interested
weracemo is offline        Reply With Quote
Old 11-25-2016, 10:37 AM   #16
Vinger
VBC gps unit works if you only use the level runs as and indication of your GROUNDSPEED, compared to actual timed runs it was within 5-10% accurate while in level flight. It is a really good tool to hone your runs with as well as validating setup changes to your helicopter.
Gaui R5, Henseleit TDR +TDR2, Banshee
Kontronik ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 11-25-2016, 11:02 AM   #17
weracemo
Thanks Vinger, I received the GPS a few days ago so I'm going to try to attach it to my swash anti rotation guide on my TDR II...
Old 11-26-2016, 04:39 AM   #18
Vinger
Just note that the Mikado GPS needs to be mounted flat with top facing up.
Old hand at Planks
