Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-21-2016, 09:30 AM   #1
jsenicka
Default TREX550X Video build
TREX550x Dominator Super Combo video build
Rotor Head -
Swash Plate -
Pitch Links -
Frame Assembly -
Jim Senicka
Team Captain, GrandRC Flight Team
Align TREX700N - TREX700E - TREX600LE - TREX500 - TREX450Pro
jsenicka is offline        Reply With Quote
Old 11-22-2016, 05:27 AM   #2
Necroscope
It looks like Align has turnbuckle linkages for the 550X and the 470L listed in the spares page of their website.
Bob1 6s with SK-720BE & GPS-1.
Bob 2 with SK-720BE
Bob 3 with SK-720BE & GPS-1.
Jeti DS-16. Whovian.
Necroscope is offline        Reply With Quote
Old 11-26-2016, 09:28 AM   #3
jsenicka
Battery Tray -
Landing Gear -
Tail transmission and boom -
Tail rotor install (optional 3 blade tail rotor used for video) -
Servo to swash links -
Servo wiring and initial setup -
3 Blade head tracking and final Microbeast Plus settings -
Jim Senicka
Old 11-26-2016, 03:29 PM   #4
KingPeter
That's great. Thanks
Sent from my XT1562 using Tapatalk
KingPeter is offline        Reply With Quote
Old 01-07-2017, 07:09 PM   #5
sbnathan
jsenicka, at the end of the last video you said you were going to do the internal governor setup in a later video... Can you post that?
I've found your videos a huge help in doing my 550x build, but I am really lost when it comes to setting up the governor.
One question is whether it's even necessary for my first few flights. If I don't setup the governor, then the system won't know the head speed, right? The manual says the head speed must be below 2700, so if I'm reading it right you just wing it based on % power output to motor using the profiles suggested on page 23 of the manual?
sbnathan is offline        Reply With Quote
Old 01-10-2017, 10:04 AM   #6
fenwick
Thumbs up
Thanks for a great build thread jsenicka.
I one thing I didn't like about the 550x design is the M2x3.5 ball link for the tail servo. You only get a couple threads out the back of the servo horn and they provide the crappy M2 nut(not a lock nut) to secure the ball link.
I used my Dermel to reduce the thickness of the horn a little so I had enough threads showing to use a lock nut. The design is a guaranteed future problem if you don't modify it to your liking IHMO.
Again thanks a ton for a great build!!!
Three Cheers
John - aka Fenwick
Protos V2 800 EVO
TREX 500L Dominator; Goblin 500 Sport
TREX 550X; Blade 230S; Ikon, Brain DX9, DX18, JR12x
Planet Earth - Field Rep
fenwick is offline        Reply With Quote
Old 01-10-2017, 11:53 AM   #7
ic-racer
I used a different, thinner, servo arm from my servo arm box of spare parts. Yes I actually saved all those servo arms that came with every servo I ever bought in the last 20 years....
HiSky HCP60, Trex-100, Trex-150, Trex-250, Trex-450L, Trex-550X
ic-racer is offline        Reply With Quote
