Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-22-2016, 02:50 PM   #1
yakky
Default 500L Servo Recommendations
I picked up a 500L kit recently and need some servos to go along with it. I'll probably be running an Ikon or Vbar on it, just doing some sport flying, loops and what not, maybe going inverted soon.
Don't really want to spend over $200 for the the set, I'm thinking KST 515s for cyclic and 565 for the tail. Anything else I should consider?
yakky is online now        Reply With Quote
Old 11-26-2016, 09:26 AM   #2
bad007
That's the setup I have. The tail servo required shaving a bevel on the inside ends of the frame. Either that or split the servo and reassemble it after the top of the case was mounted. Happy with them.
Align 450Pro 3GX Edge KDBB, Align 500 DFC 3GX, Align 500L MicroBeast Plus HobbyWing Platinum Pro V4 Plus Switch Blades, KST HV Servos, Align 550 DFC MicroBeast Plus, Velocity 50 Vbar 5.3 Pro, OS55 HZ-R, Radix V2 KDBB Castle,
bad007 is online now        Reply With Quote
Old 11-26-2016, 09:55 AM   #3
yakky
Cool, thanks for the info about the tail servo being a bit of a tight fit.
Old 11-26-2016, 10:23 AM   #4
Number
The KST are great options, but consider the new Align mini servos too. I haven't used them but I'm liking the micro size a lot so far.
Number is offline        Reply With Quote
Old 11-29-2016, 11:31 PM   #5
tacomaster
The newest align mini's are amazing so far. I'm running them on the cyclic on my goblin 500. Huge improvement over the savox.
I fly dem dere helio-co-popters
tacomaster is online now        Reply With Quote
Old 12-08-2016, 11:58 AM   #6
zzyzx_cm
the kst 515 are the best value Ive seen for mini cyclic servos
zzyzx_cm is offline        Reply With Quote
Old 12-08-2016, 12:14 PM   #7
yakky
Thanks guys, I have the KSTs coming from Banggood. I tried to buy them at Aloft but they can't seem to keep stuff in stock and won't let you order if it is out of stock.
