Old 01-03-2017, 08:20 PM   #21
nynextel88
When you say you ordered all the new red gears does that include the front drive gear set? If so, you'll have to use the new 102T auto gear and you'll have the new ratio.
nynextel88 is online now        Reply With Quote
Old 01-05-2017, 11:01 PM   #22
Mike Reed
Yes I got the 102 autorotation gear & 23t front drive gear. I'm just not sure if i have good tail authority because I had 104/ 22t gears before . I was running 1950rpm Now with new motor 2250rpm
Mike Reed is offline        Reply With Quote
Old 01-06-2017, 11:57 AM   #23
hirobo
Is anyone using these gears with VBar ??
I'm not having success.
Tail is not spinning smooth and has no command authority.
Gain is around 100% and 2150rpm.
hirobo is offline        Reply With Quote
Old 01-06-2017, 03:28 PM   #24
daboxe
What does tail not spinning smooth mean? Video?
How much work have you put into the tail (smoothness, grease, bearings, etc...)?
daboxe is offline        Reply With Quote
Old 01-06-2017, 03:43 PM   #25
daboxe
This is interesting. I got another kit and it looks like the red gears are now standard.
Old 01-06-2017, 04:09 PM   #26
Grumpy_Old_Man
It's looking certain that the old black gears and the matching 104t auto gear are discontinued in favour of the new low ratio ratio gear set. This is now being stated in some parts listings: http://www.aligntrexstore.com/104T-M...XX_p_2294.html
This is a real shame IMHO because not everyone is interested in flying screaming headspeeds and for those of us who prefer a slightly lower RPM the old gear set was better and was perfectible reliable.
This seems to be a recurring theme with Align. They did the same low ratio tail 'trick' with the 550 and 600 pro and never heeded the endless complaints that followed.
Would it have been too much trouble to keep making both gear sets and let us have a choice?
KDS Agile 7.2 | Goblin 770 Carb. Comp | Goblin 630 Comp | Trex 600Pro (626 stretch) | Kasama Dune 600 | Compass 7HV U | Trex 700X | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 01-06-2017, 04:49 PM   #27
daboxe
I think you can also use a 21tooth from the nitro model. That's if the auto gear hangs around...
Old 01-06-2017, 04:57 PM   #28
Grumpy_Old_Man
It's the auto gear that's showing as discontinued. And no, you cant use the 21t spur gear off the nitro, at least not without slotting the holes for the tail mount.
Old 01-06-2017, 11:42 PM   #29
Flyingzook
Default 700x Tail Gears - Whats the deal here?
Couldn't agree more. It would be crazy if they only sold the new ratio. Also the 700N uses the 104T gear and surely they can't expect all the nitro blokes to start running 2100+rpm can they? I like align heli's and own multiple sizes but the new ones really lack adjustability and because you can't adjust anything when they force these "upgrade! So you can do awesome sweet 3D at a million rpm" it really annoys me!
Flyingzook is offline        Reply With Quote
Old 01-07-2017, 04:19 AM   #30
Grumpy_Old_Man
That's a very good point! I'm pretty sure that the Nitro cant use the new red gear set off the 700X anyway. The frame spacing between main shaft and tail box must be ever so slightly less on the nitro to accommodate the smaller 21t spur gear that it was designed for. Web sites are listing the new red gear set and 102t auto as a 700N spare, but the official Align data on the new gear set (as I'd expect) doesnt list it as compatible with the 700N
It's a bit of a mess... Luckily i managed to find a dealer here in the UK that had one of the 104t auto gears in stock, so I've bought that along with a spare black front TT gear set. I should be ok for the foreseeable future.
Old 01-07-2017, 08:19 AM   #31
MAJ1C
What about running 115 tails on the new ratio can you squeeze those with stock setup and blades or is it a case of needing a longer backend.
MAJ1C is offline        Reply With Quote
Old 01-07-2017, 11:07 AM   #32
Grumpy_Old_Man
There is only 8mm clearance between the stock 106mm tails and the stock 700mm mains, so running 115 tails would be a bit risky, unless you used 690mm blades. You would probably get away with it 99% of the time but the risk of the blades clipping is there.
You can use the 700N tail boom, TT and pushrod to do a mild stretch to make it safe.
Old 01-07-2017, 01:37 PM   #33
mmgbrouwers
Smile
Or try to find a 3 bladed tail?
mmgbrouwers is offline        Reply With Quote
Old 01-07-2017, 06:38 PM   #34
hirobo
Angry
Are the red gear the strongest ??
I do not believe.
What is the solution??
Old 01-07-2017, 06:50 PM   #35
Hopester
I stripped the black gear on the lower drive gear that rides the autorotation gear. My umbrella gears survived. How did that happen? Almost looks like bad mesh.
RCHN 791, SAB 500 & 700C, JR Forza 700x2 (one night rig), Align 700x, Synergy E5 stretched to 625, Spartan Vortex FBL.
Hopester is offline        Reply With Quote
Old 01-07-2017, 06:52 PM   #36
Hopester
Definitely not comforting to see the stronger gears stripped.
Old 01-07-2017, 07:51 PM   #37
hirobo
I left the maneuver kaos, tail wagged and lost control of the tail
Old 01-07-2017, 07:57 PM   #38
MS60
Well they are inexpensive, and lightweight.
X3, 480XX, 600SX, Diabolo, 8FG
MS60 is offline        Reply With Quote
Old 01-07-2017, 11:38 PM   #39
darknight736
dont think align discon 22t gear t-800 still use it. H70G001AXW this number still listed from align web site I suspect a mistake from aligntrexstore
trex 800e pro dfc, trex 700n dfc, trex 450l 6S, trex 150
darknight736 is offline        Reply With Quote
Old 01-08-2017, 01:49 AM   #40
Thestructured
That kind of stripping was most likely bad mesh.
Trex 700L spirit pro / Trex 700n spirit pro/ Trex 550 Pro DFC spirit pro / 180 cfx / 230s night version
Thestructured is offline        Reply With Quote
