Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-30-2016, 10:57 PM   #1
Roger Palacio
Default T-Rex 550L three blades
I finally finished my new build. I'm having some tail issues, the tail it's kicking when I do hard 3D maneuvers. I just re-calibrate the esc to 2450 on governor mode. I will test tomorrow to see what else I can do to get this fixed.
Any thoughts ?
ID:	682514   Click image for larger version
ID:	682516   Click image for larger version
ID:	682517   Click image for larger version
ID:	682518   Click image for larger version
Align T-Rex Family Owner - MicrobeastX - 7200BX
450 Dominator, 500 Dominator, 500(Airwolf) Four Blades, 550 DFC, 600N DFC OS55HZ, 700N DFC 105HZ-R, 700 DFC HK4525-520LE
Roger Palacio is offline        Reply With Quote
Old 11-30-2016, 11:49 PM   #2
MajSlayer
Smile
You most likely need to add some Torque precompensation (RevoMix).
http://wiki.beastx.com/index.php/Man...metermenu_F/en
I had to enable this feature, once I installed new 6200Mah 40c batteries and used XT-90S connectors.
On my Pulse 5000Mah 30c batteries this wasn't a problem.
I noticed doing hard pitch pumps the nose would go left when increasing the cyclic quickly then right when decreasing. (Just about an inch or two..)
The 550X or L both have a ton of power, so this "could" be the problem.
It's most likely just causing so much torque at times that it needs the setting listed above enabled.
Fine collective management can resolve this problem, but this is most likely not what you're looking for. (I wasn't)
Anyhow just my 2 bits, and I like your 3 bladed head, looks sweet, ordering one myself tonight.
Peace,
MajSlayer
Align 550L Dominator, Align 550X, Vigor 60 CS (O.S. 61SX-H WC), Raptor 30v1/v2, O.S. 37-SZ-H, Nexus 30-S, A.S.P .37-H, JR Ergo Z230 with Scale JR Schweizer 300, Scale Bell 222 (O.S. 61SX-H WC) X-Cell mechanics.
MajSlayer is offline        Reply With Quote
Old 12-01-2016, 04:17 PM   #3
Roger Palacio
Thank you I will try it and see how it goes
Old 12-14-2016, 10:42 AM   #4
jsenicka
my gut says the 3 blade head on a 6S system is loading it enough on major pitch changes to cause you a bit of bog? That causes tail speed slowdown
Precomp on the BeastX will help
Jim Senicka
Team Captain, GrandRC Flight Team
Align TREX700N - TREX700E - TREX600LE - TREX500 - TREX450Pro
jsenicka is offline        Reply With Quote
Old 01-02-2017, 10:24 PM   #5
Jixar
off topic> Awsome bird!!! what size scorpion motor do you have in there if its a 4025 1100 how did you mount it and what size pinion are you running
Jixar is offline        Reply With Quote
Old 01-08-2017, 01:36 AM   #6
Thestructured
Something nobody else has mentioned:
How much pitch are you running? With Trex 550's I've found that running more than the pitch in the manual can easily cause tail holding problems.
The manual basically says +/-12 max and since you're running three blades you should reduce it even further since you have an extra blade producing lift. Try 10 or 11 degrees of pitch and see if that helps.
Reducing governor response gain could help if that doesn't, and like others said you will likely need to retune gains for the tail since the setup has changed. Avoid adding tail precompensation, retune everything without it, and try to solve the problem a different way first. Precomp should be done as a last resort if nothing else works.
Trex 700L spirit pro / Trex 700n spirit pro/ Trex 550 Pro DFC spirit pro / 180 cfx / 230s night version
Thestructured is online now        Reply With Quote
Old 01-08-2017, 09:40 PM   #7
Roger Palacio
Thank you!! I'm running 12s set-up with 16t pinion. I found more power with that set up. the motor its 4035-530kv. I ordered a KDE 530kv motor that I want to try.
Old 01-08-2017, 09:42 PM   #8
Roger Palacio
I reduced the pitch to 12 degrees 2400HP and problem fixed. I haven't been able to fly lately since the weather won't allow it. Once the weather allows I'll make a video.
