Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-05-2016, 02:59 PM   #1
DaveScott
Question Advice on Tools Please
I'm gathering tools together ready for my purchase of Trex 500 in the New Year, and I've already bought a mini electric drill. Do I need Metric or Imperial bits for the build. Thank you.
Trex 500l Dominator (building).
DX6 - Phoenix.
Club: Long Eaton Model Aircraft Club.
DaveScott is online now        Reply With Quote
Old 12-05-2016, 03:01 PM   #2
JEEPWORLD2002
As far as I can recall its all metric 1.0/1.5/2.0/2.5/3.0 Allen heads
Trex600n,Trex500,MR25,MikadoLoGo5003d/KDE,Goblin 380XNova,CastleCreations,Ys,JR XG8,Tags Mini XBus Dmss//FAA# FA3NYC9TAP. Keystone rc club.
JEEPWORLD2002 is offline        Reply With Quote
Old 12-05-2016, 06:26 PM   #3
DaveScott
Thanks for your reply. Just as I thought.
DX6 - Phoenix.
Old 12-05-2016, 09:10 PM   #4
ic-racer
If you wind up without the correct bits, you can easily break the "L" shaped ones that come in the kit at the bend (they break and don't bend) and then chuck the straight part in your drill.
Personally I'd do it all by hand on a 500. My 550 had nothing that needed a powered driver. Most screws go into metal and can be rapidly inserted and removed by spinning a hand held driver at the shaft between you fingers.
Maybe you got a powered driver with a more delicate clutch than mine.
HiSky HCP60, Trex-100, Trex-150, Trex-250, Trex-450L, Trex-550X
ic-racer is offline        Reply With Quote
Old 12-05-2016, 09:36 PM   #5
Thtasher
Never used a drill on a heli screw yet ( unless of course doing a modification). Get yourself a decent set of drivers like MIP and you'll be good to go.
Goblin 570(12s),Trex 500Pro,Trex 450Pro.
MD500E(600), Airwolf(500),Agusta A109(Blade400)
Thtasher is offline        Reply With Quote
Old 12-07-2016, 05:23 PM   #6
CrashNburn420
+1 on the MIP! They are a little expensive but they're worth the price.
CrashNburn420 is online now        Reply With Quote
Old 12-08-2016, 11:53 AM   #7
zzyzx_cm
i use mip drivers. 500 dominator 1.5, 2, 2.5mm is all you'll need. make sure to have another 2.5 allen or something for the feathering shaft bolts
zzyzx_cm is offline        Reply With Quote
Old 12-08-2016, 03:19 PM   #8
DaveScott
Why is this?
DX6 - Phoenix.
Old 12-08-2016, 04:29 PM   #9
zzyzx_cm
you'll need something to hold it while you torque down the other side
Old 12-08-2016, 04:32 PM   #10
Bhujang
Get a decent solder iron work station. You won't regret it. Also a magnifying lamp.
mCX2, Nano cpX Stock, Nano cpX wild BL with HP03 t for tail, nano cpX bl mild, nano cps, mcpX v2, 130X , 180cfx, 450X on a DX8, Phoenix sim, for fpv Phantom 3 pro
Bhujang is online now        Reply With Quote
Old 12-08-2016, 05:32 PM   #11
DaveScott
Any recommendations for the solder iron? Thank you.
DX6 - Phoenix.
Old 12-08-2016, 05:33 PM   #12
DaveScott
Just ordered a set of MIP drivers. Thank you.
DX6 - Phoenix.
Old 12-08-2016, 05:33 PM   #13
DaveScott
Understood. Thank you.
DX6 - Phoenix.
Old 12-11-2016, 06:11 PM   #14
Dylan Hudock
You will definitely need a soldering iron and the associated tools for it. I would suggest weller, but any decent brand and atleast 40w will work. I use 80w and it is more than enough.
KBDD Team Pilot Trex 700-500-450, Gaui X3
Dylan Hudock is offline        Reply With Quote
Old 12-11-2016, 10:46 PM   #15
zzyzx_cm
i used the same $50 aoyue 937 for like 3 years before i replaced it. it still works, i just got something better. it takes hakko tips and i used it for pretty much everything. i needed to preheat bigger escs and wires but it got the job done. i solder a lot too. the ones from sra soldering supposedly have higher qa standards but thats just what i heard.
also just saw the mip 1.5 2 2.5 set on amain for 25 bucks. i paid 40 i think.
Old 12-11-2016, 11:21 PM   #16
CrashNburn420
Default Advice on Tools Please
$25 for the 3 pack of those is a good deal!
Old 12-11-2016, 11:30 PM   #17
zzyzx_cm
it was good enough to get a 2nd set that will just stay in the 500 bag so i dont have to take the ones off my bench.
