Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-08-2016, 10:39 AM   #1
DaveScott
Question Degreasing
Is it necessary to degrease threaded screws etc on a new Trex 500L?
Trex 500l Dominator (building).
DX6 - Phoenix.
Club: Long Eaton Model Aircraft Club.
DaveScott is offline        Reply With Quote
Old 12-08-2016, 10:54 AM   #2
yakky
A good idea, probably. Necessary, nah. If you are worried, use an oil tolerant thread locker.
yakky is offline        Reply With Quote
Old 12-08-2016, 11:03 AM   #3
JEEPWORLD2002
I always dip wipe and redip on a new screw. Ill see the orangeish protectant come off. Some dip in actone. But then the heads rust so I do above to thread. On heavy load I use a 609 green but just the very top threads as its ment to penetrate a pre fastened tread from out side. Sum times requires heat to free. But yes blue 409 n oil will not work well
Trex600n,Trex500,MR25,MikadoLoGo5003d/KDE,Goblin 380XNova,CastleCreations,Ys,JR XG8,Tags Mini XBus Dmss//FAA# FA3NYC9TAP. Keystone rc club.
JEEPWORLD2002 is offline        Reply With Quote
Old 12-08-2016, 11:49 AM   #4
zzyzx_cm
i didn't think so until i had some start coming loose on me because the threadlocker didn't take. now i just use a little cup of paint thinner or something next to the tl.
zzyzx_cm is offline        Reply With Quote
