Go Back   HeliFreak > R/C Helicopters > Speed Helicopters
Speed Helicopters Speed Helicopters. Any brand as long as it goes FASSSSSSSSSTTTTTT!
Old 12-21-2016, 09:22 AM   #21
felopaul
dear
i put a csv file on my server : http://www.felopaul.com/poub/futaba.csv
Laurent B
Goblin Speed
, Goblin 570 KSE,Goblin 380
Radio: T18SZ
felopaul is offline        Reply With Quote
Old 12-21-2016, 04:37 PM   #22
iscripter
WOW, this is awesome
I have ordered a Powerbox 2 GPS and it should be here by year end. Will the data it produces through my JETI work with this software? Or do I have to have the JETI GPS sensor?
My favorite thing about your software is how useful it will be in helping me practice my runs. The way it visualizes the data in Google is perfect and clearly shows me if I am diving through the course.
Citizen 682 | Gaui X3-Spartan VX1n | Gaui X5-Spartan VX1e | Goblin 700 Speed-Spartan VX1n
JETI DS-14
iscripter is offline        Reply With Quote
Old 12-21-2016, 04:39 PM   #23
KiloXray
The data from my runs posted earlier was from a Powerbox2. No need for a Jeti GPS sensor.
Prtos Max 806-- Prtos 380 -- Prtos 380 Speed -- Jeti DS14
MSH USA - Brain Test - Xpert Servos - Lynx
RCHN Citizen № 268
KiloXray is online now        Reply With Quote
Old 12-21-2016, 05:03 PM   #24
Tomy.
Kilo is absolutely right. I've worked on the Jeti import from spec and a few sample files like Kilo's. Although I don't have a Jeti, my understanding is that the GPS data (in this case powerbox2) is pumped through the Jeti RX to the TX and then exported into the .log file. AFAIK the .log file produced is the same even with a different actual GPS unit (jeti vs. powerbox). My expectation at this point is, that if you can export the data into the .log with the Jeti, the software should be able to import it. If you find out something else please let me know so we can look into it.
I am a Heli-Coholic! 207
PRTOS Max v2 PRTOS 380 Speed Goblin 380 Blade 180CFX
MKS KDE MSH Brain
Tomy. is offline        Reply With Quote
Old 12-21-2016, 05:06 PM   #25
Tomy.
Awesome, thank you, this looks simple enough will probably do it tonight. A few quick questions:
1) what GPS/RX/TX do you have that this file is related to?
2) what should this be called (I see it has to do with futaba from the file name), so it's reusable without confusion for others too?
3) how do you produce this file? Is it an actual futaba radio or software output or something else?
4) Is there any option when you are producing this file that can change the CSV format? (for example lat/long can be decimals or minutes, or altitude speed can be imperial or metric) so I can put those into the importer so it can handle those options
MKS KDE MSH Brain
Old 12-21-2016, 05:07 PM   #26
Tomy.
Originally Posted by KiloXray View Post
That's super cool Tomy!
Thank you for your work!
Thank you Rob for the data and info you provided that helped with some of the work!
MKS KDE MSH Brain
Old 12-21-2016, 06:22 PM   #27
felopaul
1) I have a TX Futata T18SZ with RX7008 with Sensor Futaba GPS Sbus2 and Futaba RMP Optic Sbus2. TX save in File .FLD on SD card, i need a soft to convert this FLD to CSV http://downloads.hobbico.com/softwar...r_eng_V1_4.zip
2) when you convert FLD to CSV, you can chose file name CSV
3) CSV is like converter soft maked it, i changed nothing, so it's fix (order , name ..)
Laurent B
Goblin Speed
Radio: T18SZ
Old 12-22-2016, 03:01 AM   #28
Tomy.
Wink Futaba import
Laurent, I think I got something here. I will do some cleanup and put the installer up on the share. I'll let you know when it's there. Here's how your fastest passes look like from the file you sent. It looks like you were practicing left-right runs right ;-)?
By the way it seems you were taking up left from the runway, can you confirm that that's true and not my calculations are messed up?
ID:	685162   Click image for larger version
MKS KDE MSH Brain
Old 12-22-2016, 03:10 AM   #29
felopaul
Yes it good ! Fly is like You show
Laurent B
Goblin Speed
Radio: T18SZ
Old 12-22-2016, 09:23 PM   #30
Tomy.
I've updated the installer with the Futaba import module. The download link is on top of the first post in this thread. Enjoy!
MKS KDE MSH Brain
Old 12-23-2016, 07:03 AM   #31
felopaul
hello
i have en error message : "The format of the input string is incorrect."
i change parameter in setting, but the same
i used the file futaba.csv that i gave you.
Laurent B
Goblin Speed
Radio: T18SZ
Old 12-23-2016, 07:44 AM   #32
Tomy.
hello
It looks like several loggers/converters are not region and default format aware. Europen standard numeric format says that the decimal separator is a "," but futaba as well as jeti exports the numbers in the log with "," for some data and "." for some other data, and the log file becomes a mess to properly read. I will need to fix quite a few things in the program to make it play nice with the mixed format exported data. It'll take some time. For now one thing you can do is set you region in Control Panel\Clock, Language, and Region to United States and your formats also to US temporarily while you are using the program since I know that works. I'll iron this out and post a new version, but given that Christmas is coming up it'll be a few days. Sorry about it.
MKS KDE MSH Brain
Old 12-23-2016, 08:41 AM   #33
Tomy.
OK, I found a simple and clean way to deal with the mixed format files quickly. I put a new version on the share, feel free to try it. I set my machine's region and format to French and it seems to be fine. Let me know if you run into any issues ;-).
MKS KDE MSH Brain
Old 12-23-2016, 11:14 AM   #34
felopaul
It's works perfect !!! thank you , you are the best !
Laurent B
Goblin Speed
Radio: T18SZ
Old 12-23-2016, 11:30 AM   #35
felopaul
i start a post in a French forum
http://forum.heli4.com/viewtopic.php...5603#p10507636
Laurent B
Goblin Speed
Radio: T18SZ
Old 12-23-2016, 05:12 PM   #36
Tomy.
You are welcome. Thanks for the French post!
MKS KDE MSH Brain
Old 12-29-2016, 02:15 PM   #37
LoveToFly1
this is really cool bud. a lot of good work. wish the hobby had more guys like you in it!
Gasser Mike
Team Synergy, Team KDE Direct, Rail Blades, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote
Old 12-31-2016, 06:12 AM   #38
Tomy.
Thank you. This looked like a great opportunity to connect my hobbies. I'm still working on improving the algorithms and hope to get a face-lifted version out sometime early next year.
MKS KDE MSH Brain
Old 01-01-2017, 10:28 PM   #39
iscripter
Ok I finally got some good weather and I now have my Powerbox GPS2 and I have copied my Jeti .log file to my PC and tried to import it into the program but I am also getting a error message.
"Input String was not in a correct format. Analysis failed."
I am using version 0.8.2.0 of the program. I have attached my .log file just change the name of the file and remove the .txt at the end. I had to change the file extension to get the forum uploader to let me attach the file.
Thanks for the help.
JETI DS-14
Old 01-02-2017, 09:24 AM   #40
Tomy.
I fixed it. It seems in your log there are 2 sensor output data streams for "speed" datapoints, but only 1 of those have the actual data, now the importer can handle these special cases.
I've copied the new version to the share. You should see the Jeti importer version bumped from 0.8.1.1 to 0.8.1.2. Have fun!
MKS KDE MSH Brain
