Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-10-2016, 04:42 PM   #1
cholmondely
Default Ds530 servo help
Hi does any one know the frequency for using ds530 servo on cyclic for a 500 dominator ,I have looked everywhere nothing am trying to set my 3digi up and the 530 is not listed on drop down list either
cholmondely is online now        Reply With Quote
Old 12-11-2016, 12:18 PM   #2
tonys-heli
1520 us according to Amain's site..
Synergy E5s - Logo 600sx, 480xx - Gaui X5 formula, X3-380 - Goblin 500/420/380 - Protos P380
Trex 550 / 500..oxy3 - 300cfx..all hobbywing / vortex
tonys-heli is online now        Reply With Quote
Old 12-11-2016, 11:43 PM   #3
zzyzx_cm
they can handle 333hz but ive never used a fbl that made me specify cyclic frequency, only tail. center pulse is 1520. it has the same parts as the 515, 525, and 535. only the gears are different, motor as well for the older 6v max servos. the boards have a different layout but i dont see much difference at a glance, probably just a few resistor values for the higher voltage.
zzyzx_cm is online now        Reply With Quote
Old 12-13-2016, 05:01 PM   #4
cholmondely
Thanks for that will try 333mhz it insists on frequency in setup .
I fried an emax on my other heli having frequency to high so didn't want to chance it
Old 01-02-2017, 03:14 AM   #5
Number
Brain/iKON lets you select cyclic servo frequency. I have always used 250Hz on all digital servos and never had an issue.
DS530M are much improved over the 515. Much more powerful motor, improved PCB design (not just changing a few resistors...? That's not how electronics work lol), better back EMF filtering, and better cooling to motor from the machined case. Not to mention HV.
Number is online now        Reply With Quote
Old 01-18-2017, 03:55 AM   #6
zzyzx_cm
Higher voltage using the same controller ic not much there. That emf backfilter shit? bigger tantalum cap. Scope it theyre about the same
Old 01-18-2017, 08:06 AM   #7
Number
lol
Old 01-18-2017, 07:40 PM   #8
Relisys190
im running 8.4 volts 1520us / 333hz
They are great servos
*LINKS*
* G660c IKON * T-rex 500 *308DUO *450x #429
Relisys190 is online now        Reply With Quote
Old 01-18-2017, 08:02 PM   #9
zzyzx_cm
Originally Posted by Number View Post
lol
Lol is right. I wasnt surprised to see you live in mizura.
Ad hominem
