Go Back   HeliFreak > R/C Helicopter Support > 800 Class Helicopters
800 Class Helicopters 800 Class Helicopters
Old 12-21-2016, 10:38 AM   #1
msallua
Default Installing 700X head onto a 800E PRO DFC
Hi
Any chance I can put a 700X head onto a 800E PRO DFC ??
Thanks in advance
Align 800e PRO DFC // Align 700N DFC, 105HZ-R HV // Goblin 700Comp // Goblin 420 // Align 700E DFC HV.// Futaba 14Sgh - RealFlight 7.5 // neXt - Powered by Pulse - IKON's // Castle ESC's
msallua is offline        Reply With Quote
Old 12-23-2016, 08:57 AM   #2
nynextel88
Originally Posted by msallua View Post
Hi
Thanks in advance
Well, unfortunately I cannot personally try it however I will say that because the shaft length is the same, the only change of the shaft is that there is a jesus bolt that goes straight through on the head block instead of the 2 pinch type bolts on a DFC head.
I really don't see any reason why it wouldn't work just the same as it does on a 700X.
nynextel88 is online now        Reply With Quote
Old 12-23-2016, 09:48 AM   #3
msallua
hi, thanks , I think ... I need do the same job
"Darrick Chekas tip"
Drilled out the top hole's with a 4mm in order to accommodate the 700X Hub with both jesus bolt
http://www.helifreak.com/showpost.ph...5&postcount=22
I replace the 700e dfc and the 700N DFC ... with the new 700X head.
I love how the feathering shaft fit in the new 700x hub....
Old 12-23-2016, 11:07 AM   #4
nynextel88
Yes you can drill out the shaft or you can purchase the new one for the 700X if you aren't comfortable with drilling out the threads.
