Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-22-2016, 07:16 AM   #1
DaveScott
Default Restraining
In the Spektrum DX6 Instructional Manual, it refers to restraining the heli on the ground. How do I do this? Thank you.
Trex 500l Dominator (building).
DX6 - Phoenix.
Club: Long Eaton Model Aircraft Club.
DaveScott is offline        Reply With Quote
Old 12-22-2016, 07:34 AM   #2
Crashalotjoe
I think this advice is both bizarre and wrong in equal measure - certainly for flybarless heli's. You may get away with it on a flybarred heli but it causes all sorts of complications with flybarless, some of them dangerous to either the heli or the user (or both).
Mark
So many heli's, so little time.
Crashalotjoe is online now        Reply With Quote
Old 12-22-2016, 07:37 AM   #3
DaveScott
Hi Mark - Thanks for your reply. However I don't understand - could you explain further. Thanks - Dave
DX6 - Phoenix.
Old 12-22-2016, 08:06 AM   #4
HeliLust
When you restrain a helicopter to the ground it is possible that the heli could explode into pieces. It has to do with vibration and resonant frequencies that can be introduced while Being restrained.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 700N
Team Align Enterprise Hobby Facebook Align Part Finder
HeliLust is offline        Reply With Quote
Old 12-22-2016, 09:53 AM   #5
Crashalotjoe
It partly relates to vibrations and ground resonance and partly to the action of the flybarless controller. If you consider that the flybarless controller (FBL) is trying to keep the heli in the orientation that the sticks require. If it senses that it needs to put in say a bit of left aileron and it doesn't get any feedback that the heli has actually moved (because it is restrained) then it tries to put in more and more aileron until it is maxed out. With all control directions doing the same thing, chaos ensues. If the heli is just tethered and not totally constrained, bad things happen.
I'm assuming that the suggestion to restrain relates to carrying out transmitter function tests. IMO, the only way to do this safely is to remove the blades so all controls can be checked (even spool up) without significant danger. If you're only doing a servo test and don't need to spool up, you could just disconnect the motor.
I hope this helps
Mark
Old 12-22-2016, 10:13 AM   #6
yakky
Not a good idea. I just had an incident where my "restrained" 180CFX decided it wanted to eject its boom. It wasn't really restrained, I was testing head speed on carpet and the skids AND tail somehow got stuck in the carpet. It did this incredible death shake from 0-insanity in a fraction of a second. The tail got all twisted up and almost ripped off.
Helibargains.com Heli Only Deal Site
yakky is offline        Reply With Quote
Old 12-22-2016, 11:31 AM   #7
tonys-heli
yea, tail fins don't like getting stuck in anything..dirt/grass/carpet..makes the fbl go crazy..my ar7200
was intolerant of this..im using Spartan vortex now and its
much more forgiving..but never restrain a heli for reasons stated above..
Synergy E5s - Logo 600sx, 480xx - Gaui X5 formula, X3-380 - Goblin 500/420/380 - Protos P380
Trex 550 / 500..oxy3 - 300cfx..all hobbywing / vortex
tonys-heli is online now        Reply With Quote
Old 12-22-2016, 11:59 AM   #8
Ah Clem
What everyone stated above it correct!
Restraining a helicopter on the ground is potentially very dangerous.
Old 12-22-2016, 12:18 PM   #9
DaveScott
Hi Guys - My apologies - The article refers to fixed wing! Doh! Thanks for you replies.
DX6 - Phoenix.
