Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 01-05-2017, 01:44 AM   #1
Jixar
Default BL_730mx head speeds
what kind of headspeeds are guys running with their stock dominator motors im using the governor in my castle 120 at 1900 2100 and 2300 im just waiting for a weather window to try this out. Is this ok?
Jixar is offline        Reply With Quote
Old 01-05-2017, 10:41 PM   #2
Thestructured
If you mean the 850kv version in the 550L and 550 dfc pro, for casual and sport flying 2300 or 2400 is ok. For 3d flying you can govern it at 2500 rpm or run a flat 100% curve.
So basically:
2500 if you are pounding on the heli and want the most out of it.
2300-2400 for sport flights and mild 3d
2100 for gentle flights. Under 2100 will actually be bad for your esc and batteries with the stock gearing.
Trex 700L spirit pro / Trex 700n spirit pro/ Trex 550 Pro DFC spirit pro / 180 cfx / 230s night version
Thestructured is offline        Reply With Quote
Old 01-08-2017, 10:59 PM   #3
Jixar
Default head speeds
Thanks! ill give it a try !!
