Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 01-05-2017, 01:46 PM   #1
Memphis3
Question 470L Drive Gear Mount & Bearing Shaft
My 470Lm kit had a tight main shaft. Had to grind down the ID a little to fit and may have taken off a little to much.
470L Drive Gear Mount H47G002XX$12.99
470L One-way Bearing Shaft H47G005XX $3.99
These look to be the same or similar and can you disassemble the Drive Gear Mount and install One-way Bearing Shaft
Memphis3 is offline        Reply With Quote
Old 01-06-2017, 04:53 AM   #2
Andy from Sandy
It will all come apart. It could well have been assembled with retaining adhesive so you will need to use heat and maybe a press or vice to get it all apart.
I would of been inclined to of polished down the main shaft with some oil and wet and dry paper with it spinning in a drill.
Andy from Sandy is offline        Reply With Quote
Old 01-06-2017, 09:43 PM   #3
kevindnyc
My main shaft was also tight when rotated, just found that the bearing below the autorotation bearing is seized up. Going to contact align trex store
D420, Align 470, Align 450pro v2
kevindnyc is offline        Reply With Quote
