Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Closed Thread
Old 01-05-2017, 02:09 PM   #1
RappyTappy
Default New 470LM and already outdated parts.
Bought one LM kit beginning of December from a major shop and another a week later from another major shop. Come to find out, one kit is old and outdated already? Different blade grips with no nut holder built in (really a pita), different tail rotor bolts, different auto hub collar/bolt with nut, missing the micro hex driver, shorter tail shaft (known but apparently taking forever to get out) Even the manuals are different, the 'updated' one has more info and a sticker pasted on the page for the auto hub change, lol.
Never knew a new heli could be outdated so fast, so are they going to start using decimals in their versions now V1, V1.1, V1.2, V1.3....
Wouldve been nice to know so I couldve ordered the latest kit, instead now I gotta email Align in Taiwan, wait for a reply, wait for parts if they will even come through, ugh.
ID:	687187   Click image for larger version
ID:	687188   Click image for larger version
ID:	687189   Click image for larger version
ID:	687190   Click image for larger version
Chris
RappyTappy is online now
Old 01-05-2017, 02:18 PM   #2
perrypoint
Wouldve been nice to know so I couldve order the latest kit, instead now I gotta email Align in Taiwan, ugh.
Kudos to Align for recognizing the weaknesses and improving the design. But next time, please do it BEFORE the release so we don't end up with all this confusion and need to update parts! Maybe they were trying to hit the Christmas shopping season and rushed the release.
I ordered a replacement tail drive assembly and it came with the old (shorter) shaft. Not the end of the world, but a pain for sure.
perrypoint is online now
Old 01-05-2017, 02:26 PM   #3
Andy from Sandy
I don't see a weakness in the bottom collar. I thought that was a good idea not having a nut. What is wrong with it?
Removing the blind nut from the blade grips is just making it cheaper which I doubt they are passing on.
Andy from Sandy is offline
Old 01-05-2017, 02:49 PM   #4
RappyTappy
The nut on the bottom collar is nice because no loctite needed, just bolt and go and no worries about it ever coming loose or stripping the collar. Its just a more secure method imo.
Chris
Old 01-05-2017, 02:54 PM   #5
Andy from Sandy
...or stripping the collar.
That's not going to happen here.
Old 01-05-2017, 03:23 PM   #6
RappyTappy
Not going to derail my thread as this is not a what is a better design thread, but over time the bolt taken in and out will wear the collar threads, to each their own. *Edit* after looking at it, the new design has the shank go all the way through the collar versus the old one I have where the threads are taking side loads, not good and can lead to the bolt fracturing at that point. So yes, design flaw.
The point of this thread is its not the updated part with no mention by Align that they even updated it according to the hobby shop, they say they are in the dark that there are differences between kits except the tail shaft. Whats up with that?
Chris
Old 01-05-2017, 03:29 PM   #7
learnedthehardway
Never stripped out a collar but certainly stripped a bolt out in one which is a PITA. That was when I was new and ham fisted but agree that a nut is a good idea
People piss and moan when things take forever to be released after they're announced or when a release is delayed but that prevents things like this from happening.
x2 Mini Protos 6s stretch-SK540/KDS Chase 360-SK540/180cfx/UMX Pitts
I'm a rocker, I'm a roller, I'm a right out of controller, I'm a wheeler, I'm a dealer, I'm a wicked woman stealer, I'm a boozer, I'm a user....I'm a rock and rollin man...
learnedthehardway is online now
Old 01-05-2017, 03:43 PM   #8
RappyTappy
I never moaned about the release date and would have like to received a kit without old designs that do have flaws, totally sucks having to use a nut driver, allen driver and tighten blades.
Chris
Old 01-05-2017, 04:37 PM   #9
gimbleguy
Yeah that one i'd change to the newer version(put a longer shouldered jesus bolt).
As for the others they are more of an upgrade especially for the LP guys, but not required.
Slow and Steady FTW.
gimbleguy is online now
Old 01-05-2017, 04:41 PM   #10
Number
I know it's not a real solution, but you could use a little epoxy to secure the nut to the grip. Put the epoxy on the grip, put the bolt through, install the nut and tighten it. Let it completely cure. Next time you take the grip bolt out the nut will be glued in place. It's not ideal but it works. Might need to scratch up the surface of the grip under the nut to help the epoxy stick. Just be careful not to get epoxy in the threads.
Number is online now
Old 01-05-2017, 05:00 PM   #11
yakky
That's just how align works, the models just get updated as things go along. NBD in my book unless you are one of those that gets bothered by these kinds of things.
How's it fly?
Helibargains.com Heli Only Deal Site
yakky is online now
Old 01-05-2017, 08:02 PM   #12
RappyTappy
The only thing that isnt a big deal is the tail grip bolts. But imo the autorotation collar is disconcerting considering since I fly hard. Also, having to loosen and tighten the blade bolts everytime I go out so I can fold the blades is just a PITA thing. Guess Im just trying to figure this out as since everyone Ive talked to is thinking Im taking crazy pills.
Chris
Old 01-05-2017, 08:05 PM   #13
Number
Why would you have to tighten and loosen the bolts?
Old 01-05-2017, 08:35 PM   #14
Dogdipstick
Threads make great bearing surfaces, when bearing a nut amd / or the surfaces are small. Smaller bearing means lower friction. Low friction. Long as the load is adequately supported and designed for.
Threading bolts in and out actually hones thread mating surfaces, and work hardens the thread surface, given it is not damaged. I was shown to turn in and out head studs on high strung engines many times until the studs were seated before coating the nuts in oil and torquing the head down.
Not like I never had an engine break, or a head I put together didn't blow, though. Must be luck sometimes lol. Whatever. Stupid combustion power. I don't design rc helicopters, though, I just try and run engines (into the grave).
...So the kids they dance and shake their bones...
Align 550e & Brandkspankingnew Gaui x7 HW Xnova Pulse BD3SX Fusuno KDE Helioption Cyclones ... (Dipstick was my Jack Russels name lol.)
Dogdipstick is offline
Old 01-05-2017, 09:18 PM   #15
RappyTappy
Because I run my blades tight for flying. Dont derail my thread, makes no bearing what I like to do, but the fact that the part has been updated without any fact noted.
Chris
Old 01-05-2017, 09:46 PM   #16
Number
Do you run them so tight that they literally won't fold?
Old 01-05-2017, 09:50 PM   #17
RappyTappy
You aint gonna hijack this one. Thread closed, hopefully this sheds light to prospective buyers to make sure they dont get a old new kit.
Chris
Closed Thread
