Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 01-05-2017, 03:41 PM   #1
BgSkyFlyr
Default Spektrum radio throttle curve HS settings
Can anyone tell me approximately what percentage on the throttle curve would get me around the 2500-2700rpm range? I want to maiden with a lower headspeed to avoid any surprize's. I have the Spektrum DX6 Gen 2 Thanks
[B]Blade 120s, Blade 230s, Trex 470Lp(Ikon2mini)
Spektrum DX6 Gen2
BgSkyFlyr is online now        Reply With Quote
Old 01-05-2017, 04:08 PM   #2
learnedthehardway
http://www.microheli.com/airbrush-fi...e-250-cfx.html
Scroll to the bottom of this page and enter the tooth count for the pinion and main gear to get the gear ratio.
Then put that ratio in the headspeed calculator along with the motor kv rating. For 6s use 24v in the formula if you're using a governor and that will give you your max headspeed. Divide that by whatever thro curve percentage and that should get you in the ballpark.
Works perfectly for gov store mode on YGE/YEP esc's but should get you reasonably close using something different
x2 Mini Protos 6s stretch-SK540/KDS Chase 360-SK540/180cfx/UMX Pitts
I'm a rocker, I'm a roller, I'm a right out of controller, I'm a wheeler, I'm a dealer, I'm a wicked woman stealer, I'm a boozer, I'm a user....I'm a rock and rollin man...
learnedthehardway is offline        Reply With Quote
Old 01-05-2017, 04:41 PM   #3
Number
Google Mrmel headspeed calculator. Best one there is.
Number is online now        Reply With Quote
Old 01-05-2017, 05:10 PM   #4
BgSkyFlyr
Thanks for the help
Spektrum DX6 Gen2
