Go Back   HeliFreak > R/C Helicopters > New Member Introductions
New Member Introductions If you are new to HF, please tell us a little bit about yourself. What Helis do you fly? You will find our community very friendly, why not break the ice and introduce yourself.
Old 01-10-2017, 05:28 PM   #1
blue_92lx
Default Too new at this, please help
I recently became fascinated with r/c helicopters so I have bought a Blade 450X.... Probably not a good idea for a brand new pilot but its mine now. I've learned alot in the past few days on how this thing works after I crashed it twice. Long story short, I was re programming my receiver (ar7200bx) and now the servo up front will not respond to the servo centering part... It either runs the swash all the way up or all the way down... there's no in between. The other 2 servos react as they should by twitching and allowing them to be centered. Any idea what this could be...? Its a brand new servo.
blue_92lx is offline        Reply With Quote
Old 01-10-2017, 09:02 PM   #2
vebbyson
Welcome to this forum. There is a specific 450X forum here, lots of people still flying the 450X..
To answer your question... the servos have plastic gears and strip vey easily when crashed. To check gears, with power off rotate servo arm, it should feel smooth and no clicking, next check the servo arm itself. In some crashes, it can rotate on the servo, stripping the mesh. Causing misalignment. If so then you need a new servo arm.
Also check the push arms from servo to swash. They should be straight, and snapped on.
vebbyson is online now        Reply With Quote
Old 01-10-2017, 09:28 PM   #3
rockrawl
WOW, Tthats a big chunk in a first helicopter! Hopefully you'll get then help needed
Nano CP, 230S, 250 CFX, 360 Trio CFX, Align 470LM
rockrawl is offline        Reply With Quote
Old 01-10-2017, 09:40 PM   #4
fastflyer20
Welcome! Many of us learned on 450's, you can succeed!
If you don't have a computer simulator, grab one and use it. Find a heli pilot to help on the setup/repair and join an AMA club in your area, both are great ways to learn the ropes.
You found the best site for forum help. Search and read, then ask if you still have questions.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is online now        Reply With Quote
Old 01-11-2017, 12:25 PM   #5
Gerald01
Set the swashplate to normal on the beastx. If you set it to 120 the servos will not work properly... pretty much do exactly what you're describing.
Good luck
Align TREX 500 PRO DFC, Blade 450x, 180cfx,
Spectrum DX8
Gerald01 is offline        Reply With Quote
Old 01-11-2017, 02:00 PM   #6
PilotPin
Are you saying it's a random thing when you initialize that the servo might end in a up or down position.
PilotPin is online now        Reply With Quote
