Old 01-11-2017, 10:59 AM   #1
H3L1FR3AK
Default Trex 700x problems
Hey guys!
I just finished building my trex 700x. Everything fit pretty well, but I had an issue at the swash. I screwed the ball links in the outer hole, but one ball link broke apart and half of the thread is still in the swash.... May I use the inner hole? Or is it bad for flight performance?
I also have a problem with the main gear... After using washers to eliminate axial play and tightening the m4 socket screw, the main drive gear still has a little play, however the main shaft doesn't. Is it possible that the main gear has play on the one way bearing shaft?🤔
I hope you understand my problem and my bad englisch😆
Many thanks in advance
Moritz
H3L1FR3AK is online now        Reply With Quote
Old 01-11-2017, 07:30 PM   #2
nynextel88
It should fly ok. Just be more careful threading the balls. Let the loctite do its job. You shouldn't have any up and down play on the main gear. Something may not be assembled correctly.
Did you disassemble the one way sleeve? If so, you may have removed and left out the large washer that belongs in there.
nynextel88 is online now        Reply With Quote
Old 01-11-2017, 07:47 PM   #3
H3L1FR3AK
Thumbs up
Thank you!
Right! I disassembled the main gear. Tomorrow I will look for it again to check if sth is missing.
Moritz
Old 01-12-2017, 07:33 AM   #4
dchekas
Another possibility is the radial ball bearings in the one way hub have slipped slightly, and this will allow some up and down movement.
Disassembling the one way hub, applying some bearing retainer Loctite, and re-installing the radial bearings should resolve it.
dchekas is online now        Reply With Quote
Old 01-12-2017, 07:45 AM   #5
heli addiction
Personally if you cant remove it i would replace the swashplate, yes it would fly if you set it up with the inner holes but... having just measured my 700x swash i can tell you there is an 18% difference in length between inner and outer swash holes from center of main shaft. This will give your main blade grips to much angle, of course you can still set 12 or 13 deg at grips but you will lose 18% of the available cyclic servo travel= lower resolution eg: fbl unit now has 82 points of servo ajustment, not 100. And of course 18% more load on the servo's.Possibly drill and tap a 3mm thread then find a new ball link to suit. The main gear should not have play at all. Good luck man you will love the heli it is epic.
heli addiction is offline        Reply With Quote
Old 01-12-2017, 09:19 AM   #6
H3L1FR3AK
Post
Thanks !
I just disassembled everything and checked that the washer is installed. I haven't reinstalled the bearings, because they were already tighten and installed correctly. I put everything back together and found the problem. The play comes from the place where the one way bearing mount is on the autorotaion gear.
May I try to fix it with washers in between?
Moritz
Old 01-12-2017, 09:35 AM   #7
H3L1FR3AK
Ohhh... just saw that the lower gear isn't all the way in the Mount. Thanks Derek! I'm now going to put it in correctly.
Moritz
Old Today, 05:12 PM   #8
Dennis Everett
you might be able to remove the broken ball joint by getting a small left hand drill bit , heating to soften loctite and apply preasure on the broken ball joint with a drill in reverse ...or drill out and re-tap the hole ...
Dennis Everett is online now        Reply With Quote
