Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 01-12-2017, 01:24 AM   #1
AAirbus
Default What LiPo are you using?
Doing some research before I buy a 470 kit. They recommend 1800 mah, but they seem a bit scarce in the 6S variety. So far I've found Pulse (good, but pricey), Glacier (bad and avg), and GensAce (unfamiliar/never tried).
I really like the HK Graphene batteries, but the closest thing they have is a 1500 mah. Not sure of the run time difference vs the recommended 1800.
What is the range of battery size (in mah) that this bird can handle?
Interesting to see the feedback from those of you who are already flying the 470.
AAirbus is online now        Reply With Quote
Old 01-12-2017, 04:46 AM   #2
BgSkyFlyr
The manual for the LP kit shows 1450-1800 Mah in mine.
[B]Blade 120s, Blade 230s, Trex 470Lp(Ikon2mini)
Spektrum DX6 Gen2
BgSkyFlyr is online now        Reply With Quote
Old 01-12-2017, 05:59 AM   #3
Dipweed
Originally Posted by AAirbus View Post
Doing some research before I buy a 470 kit. They recommend 1800 mah, but they seem a bit scarce in the 6S variety. So far I've found Pulse (good, but pricey), Glacier (bad and avg), and What is the range of battery size (in mah) that this bird can handle?
On my 470Lp and 470Lm
Turnigy Graphene 1500mAh 6S 65C $37.81
6S1P 22.2V 2100mAh/20C KX870006A $12
2 Turnigy 2200mAh 3S 20C $9.99 & Harness for 2 Packs in Series $2.40
Align&HK450 L/470L/150 DFC/Blade stuff
DJI/AR Drone
Dipweed is offline        Reply With Quote
Old 01-12-2017, 07:24 PM   #4
dannym
I don't know why you rate Pulse batteries as "good" and Glacier as "bad". They are made by the same company in the same factory. I have used both and they are both good batteries (so is Gens Ace, also made by the same company).
470LM HW Platinum Pro 60A, Mini VBar
450L
HW Platinum Pro 50A, Mini VBar
dannym is offline        Reply With Quote
Old 01-12-2017, 08:10 PM   #5
Number
Glacier are definitely not bad. They are a lower quality cell but by no means bad. Just not as good and tend to puff more/sooner than Pulse. Performance wise they are very close with Pulse seeming to pull ahead most of the time.
Number is online now        Reply With Quote
Old 01-13-2017, 09:31 PM   #6
Kootenai Rider
6S 2200mah 65C Turnigy NanoTech...
6S 45C 1800mah Pulse....
Though a little heavier feeling in the air....I prefer the Nanotechs...
Kootenai Rider is offline        Reply With Quote
Old 01-15-2017, 08:22 AM   #7
hirobo
Was the turnigy batteries tight?
Is there room for her to swell?
hirobo is offline        Reply With Quote
Old 01-15-2017, 12:55 PM   #8
Andy from Sandy
Opti Power 1.6Ah 30C
Andy from Sandy is offline        Reply With Quote
Old 01-15-2017, 02:56 PM   #9
Dipweed
Default Charge time 3 minutes
Tight
No but I do use a double stick tape between the 3s
Swell or Puff install
Well I think once swelled I dump the LiPo. 3s are cheep 8$ 3s are not worth keeping once I see any puffing.
To answer your question .
Yes there is LiPo swell or LiPo puff room not much but two 3s LiPo easily slip in my 470LM and 470LP.
The only reason I use 3s LiPo is I have a few laying around. I am testing the Graphene and due to Graphene 3 or 4 minute charge time I may just stop using all my 3s LiPo.
DJI/AR Drone
Old 01-15-2017, 11:36 PM   #10
Kootenai Rider
They're snug but no rubbing. If my packs ever get puffy they go away before I worry about whether or not they fit.
Old 01-15-2017, 11:42 PM   #11
JEEPWORLD2002
Dont think You Know Exactly What your talking about?? Prestige wholesale own and operates pulse Lipo.. And Heli Direct
Glacier and gens ace are infact the same cell just rebranded packs. Glacier puts their label on pack that gens ace built...
Now for pack i recommend the pulse 1800 45c packs u can spend a few $ more for 65 but not needed.. FOr longer flight times and a heavier bird you can fly the pulse 2600 45c packs and for middle of the road the pulse 2200 45C
Now i do like the hobby king Graphene packs but not sure how it would fly with the 65c 2200s I like the 1800 65c on m,y trex 500(425) but tight getting the canopy on
Now Unless you can prove otherwise I wouldnt be making comments like above
Trex600n,Trex500,MR25,MikadoLoGo5003d/KDE,Goblin 380XNova,CastleCreations,Ys,JR XG8,Tags Mini XBus Dmss//FAA# FA3NYC9TAP. Keystone rc club.
JEEPWORLD2002 is offline        Reply With Quote
