Go Back   HeliFreak > R/C Helicopter Support > Avant RC - Mostro & Aurora
Avant RC - Mostro & Aurora Avant Mostro, Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support
Old 03-02-2011, 10:56 PM   #41
Don Omar
Default Having Fun! Aurora E
Don Omar is offline        Reply With Quote
Old 03-08-2011, 12:14 PM   #42
Laurens
Not the best vid, at 720 its still not visible all the time:
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote
Old 03-09-2011, 11:12 PM   #43
Don Omar
Default TODAY
GOOD WEATHER!
Old 03-10-2011, 09:49 PM   #44
Don Omar
NICE VIDEO! SOUNDS GREAT ! WHAT SET UP IN RPM? Mines 2100 rpm !
Old 03-18-2011, 09:14 AM   #45
kanglou
Here is my E Aurora FBL vbar 5.0.
Daniel.
kanglou is offline        Reply With Quote
Old 03-18-2011, 04:04 PM   #46
Laurens
Not sure about my rpm, I guess about 2100 too. Maybe I'll need more rpm and less pitch.
Logo 800/Jeti DS16
Old 03-18-2011, 04:26 PM   #47
kanglou
What mainblades size are we taking about?I'm running edge 713mm and a headspeed a round 2000 and pitch at 12/-12.
Daniel.
Old 03-19-2011, 01:27 PM   #48
Laurens
I use exactly the same blades, but so far + and - 13.5 degrees of pitch. This is a bit too much.
Logo 800/Jeti DS16
Old 03-19-2011, 03:24 PM   #49
kanglou
Hmm ok why don't you just drop the pitch to 12/-12 and use the same hs or drop it a littel to if you think the heli is to Quick?Or what do you mean if you wan't more hs?
Daniel.
Old 03-19-2011, 03:34 PM   #50
Laurens
Its just very fast and powerfull, I had one oneway bearing slip because of that. I'll be lowering pitch a bit.
Logo 800/Jeti DS16
Old 03-19-2011, 04:21 PM   #51
kanglou
Do you run kasama one way?if not switch to it itīs helps alot for slipering the avant stock one way.
Daniel..
Old 03-20-2011, 04:16 PM   #52
Laurens
I'm about to order one, and if that doesn't help I need a normal motor instead of this Limited edition one...
Logo 800/Jeti DS16
Old 03-20-2011, 11:58 PM   #53
kanglou
Ok try that and if you Will buy a "normal" 500kw let me know i can buy the LE motor from you
Daniel.
Old 03-21-2011, 03:50 AM   #54
djedje
Hi,
Here is mine :
Alpin Heli smack Down
Raptor G4 N & E
Raptor E700
Goblin 700 Competition
Team EZNOV
djedje is offline        Reply With Quote
Old 04-29-2011, 06:20 AM   #55
lyco46
flippin the bird...
lyco46 is offline        Reply With Quote
Old 06-01-2011, 04:15 AM   #56
djedje
Raptor G4 N & E
Raptor E700
Team EZNOV
Old 06-26-2011, 08:27 AM   #57
EWRYBADY
Hi..
Here is mine. I flew a friend's e-Aurora. Great heli !
EWRYBADY is offline        Reply With Quote
Old 07-02-2011, 06:03 AM   #58
tony stevens
tony stevens is offline        Reply With Quote
Old 07-08-2011, 11:59 PM   #59
Don Omar
HAVING FUN WITH AURORA E
Old 01-01-2012, 11:42 AM   #60
mahathyr
Default Noob 3D From Singapore- Avant E-Aurora 90
Many thanks to all the help that i got here on HeliFreak especially on to the folks that assist me on a thread here in Avant http://www.helifreak.com/showthread.php?t=363410
Changed the sprag to the Kasama sprag and replaced the sleeve as well finally manage to have few good flights with the Aurora and manage to tweak the BeastX to my liking...cheers all
Gravity Always Wins
mahathyr is offline        Reply With Quote
