Go Back   HeliFreak > R/C Helicopter Support > Avant RC - Mostro & Aurora
Avant RC - Mostro & Aurora Avant Mostro, Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support
Old 12-26-2014, 10:50 AM   #121
Rob43
AH...Powerboost, right?
= Rb43 =
Rob43 is offline        Reply With Quote
Old 12-26-2014, 03:23 PM   #122
kumar2494
Yes. OS replaced the pipe under warranty.
kumar2494 is offline        Reply With Quote
Old 01-14-2015, 01:03 AM   #123
FBLessOne
is there a known problem with the powerboost pipe?
μολὼν λαβέ
FBLessOne is offline        Reply With Quote
Old 01-14-2015, 10:55 AM   #124
kumar2494
I don't believe so. It seems like I just got one with a bad weld. The replacement had a much larger weld bead and is holding up fine.
Old 01-25-2015, 10:09 PM   #125
Rob43
Reason I assumed such, unless I am mistaken, is because the Powerboost pipe is solid construction between the pipe and exhaust flange connection. The YS pipes have a separate header with fat o-rings to seal. The connection between the pipe and header have flex grommets to take up vibrations. Much less apt to crack.
= Rb43 =
Old 03-02-2015, 02:04 PM   #126
kumar2494
Here's a quick flight I did over the weekend with the nitro. Got a little too low at the end and hit the tail in the snow, destroying the tail blades. After we got snow, it rained and everything froze which is why the tail blades shredded. I could actually walk on the snow without sinking in. The only damage other than the blades was a broken tail fin and bent tail output shaft.
Old 03-02-2015, 05:48 PM   #127
tony stevens
Nice flight!
tony stevens is offline        Reply With Quote
Old 03-02-2015, 11:43 PM   #128
Clarence Creer
Very nice flight.
Team Kontronik Team minicopter VTeam
Team YS, Team RoToR Rage
Evo Power Battery PeakAircraft
Clarence Creer is offline        Reply With Quote
Old 03-06-2015, 12:54 AM   #129
vmalpi
Cool Flight bro.
Victor M.
Team MikadoUsa/Team Cyclone Blades
/Team Scorpion/Team Xpert Servos
vmalpi is offline        Reply With Quote
Old 03-07-2015, 09:11 PM   #130
Alex M K
My good old reliable Aurora 90....hundreds of flights, and even with the Ikon completely de-tuned, with the wrong pitch, one blade off track and the wrong cyclic angle, it flew like a faithful dog!
These helis are truly amazing...
PS the Ikon off tuning was due to me using the unit on another heli and when I loaded the files back on to use it on the Aurora, I used the wrong file...the track on one blade was off and I didn't even noticed it..but you can sometime hear it flap on the flips to the right
Kind regards
Alex
Alex M K is online now        Reply With Quote
Old 04-04-2015, 04:41 PM   #131
Rob43
I was mistaken. Didn't mean "YS pipes". Meant to say "Hatori pipes".
= Rb43 =
Old 06-20-2015, 09:15 PM   #132
AlarmedBread
Default Post your Avant videos here!
Breaking it in at a fun fly! Fun heli and all the kids there agree the smokey one is the fastest!!
#HighOnHelis
AlarmedBread is offline        Reply With Quote
Old 09-13-2015, 08:20 PM   #133
sseppala
Default Avant Mostro Flight
62 year old makes first attempt at 3d (video)
sseppala is offline        Reply With Quote
