Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-23-2009, 02:09 PM   #61
jones007
Originally Posted by str8huckin View Post
It was just a joke, no harm intended. Although that question has been beaten to death and a simple search would have gotten the answer a lot faster than waiting for your response which is incorrect btw. The regular kits have the new main gear as well and possibly the metal tail grips. The only real difference between the 2 is the anodizing.
Thanks for the feedback. When I searched, I found this thread, but didn't immediately see the answer. Thanks for clarifying. If the color is the only difference, it's a bit hard to justify the additional $100.
--Kevin
Trex 500 I2RC swash/Radix/BLS153/Quark/DS520/AR7000/ICE50/Neu1706H/1.5Y
Trex 600E-Pro QUK/Radix600/BLS255HV/Quark/BLS251/AR7110/ICE280HV/HKIII4035-530
Trex 700LE Align 91H/SB20/Radix710/BLS451(8V)/DS760/BLS251/AR7100R/QUK clutch/tail
jones007 is offline        Reply With Quote
Old 02-22-2010, 04:20 PM   #62
mrwhipels
does anybody know if you can power the r617fs direct from a 2s lipo? I want to run my ds610's on 8 volts. if you can't then how are you futaba guys doing it with out getting an expensive regulator. I want to plug my 2s lipo with a switch into my r617fs rx and get the spectrum 5.2 step down to run my tail and throttle servo. I just don't want to fry my rx by powering it with 8 volts.
Any help?
mrwhipels is offline        Reply With Quote
Old 02-22-2010, 04:45 PM   #63
JAGNZ
NO - you cannot. See the Futaba specs here:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTHL6
" Power Requirement: 4.8 - 6V" 6V MAX
That is just one of several drawbacks with FAAST vs. Spektrum....
Jason Greenwood
www.3dheli.co.nz
JAGNZ is offline        Reply With Quote
Old 02-22-2010, 06:09 PM   #64
mrwhipels
So do think this would work?
I have the postive and negative wires on the servo's wired direct to the lipo and I the signal wires are plugged in to the apporiate channels. I have the 2s lipo plugged into my current RCE-B3X regulator. The regulator is plugged in the rx to power it at 5.8 volts. When i turn on the regulator it also powers a micro relay (you can get them at any electronic store) which closes the contacts and powers the servo's that run off the lipo direct. This way every thing turns on with the switch on the RCE-B3X and the 8 volt servo's are not always powered.
I am not sure if this would work but I can't really find any other way of doing it with a futaba system or buying a scott gray regulator.
I attached a diagram to better explain it
Old 02-22-2010, 06:13 PM   #65
JAGNZ
Yes, that will work. I have a similar setup on my Trex 700N because I needed step downs on throttle and tail etc. anyway. So I split my power/signal wires on my servos and did as you suggest but via a wiring harness and switch.
You can see pics of the harness here:
http://rc.runryder.com/helicopter/gallery/41507/
down at the bottom. It says 'Custom 8v Switch Harness' - click to enlarge.
On the left you see the plugs for the servos (in) and then those extra leads (they are just servo extension wires) are split for power and signal (so I did not have separate the servo wires themselves). The 3 signal plugs go into the Rx, the Deans is for LiPo (in) and the red plug is for Rx power (out) from the switch. The master switch arms the lot but I have gone one further and sent the Rx Power out to an Align 2 in 1 which provides regulated power to the Rx AND does remote glow duties. Clean and tidy setup without buying an expensive reg setup. Plus I HAVE to have remote glow now, I'm spoiled. lol.
I just leave the 2 in 1 switched on and use the Master Switch to turn everything on.
I will be SO thankful when everything can just run 8v.
Hope this helps.
Jason Greenwood
www.3dheli.co.nz
Old 02-22-2010, 06:40 PM   #66
mrwhipels
You still have to turn on your 2 in 1 seperatly right. I am trying to eliminate that.
Old 02-22-2010, 06:46 PM   #67
JAGNZ
Nope, I leave it switched on. It gets its power only when the master switch is turned on. The master switch sends power to the servos and to a servo plug which goes into the 2 in 1...look at the harness again.
Jason Greenwood
www.3dheli.co.nz
Old 06-08-2010, 07:52 PM   #68
Helico-pteron
Oh this should be good. Please list the several draw backs with FASST.
You can use the R617FS at 8.4V, don't believe anyone that trusts a 2n1.
Helico-pteron is offline        Reply With Quote
Old 06-08-2010, 08:00 PM   #69
Helico-pteron
700LE-13/13 collective, 9/9 cyclics
OS91HZ
Hatori SB20
Radix 710
Radix 105
DS620 cyclics
S9252 Throttle
S9256/Spartan Rudder
Reactor SG(6.8V)
R617FS
Outrage 5000mAh
Everyone has their own opinions on power systems so it's kind of a moot point.
I've had a couple YS motors and the OS has more power IMHO. You can keep your paper statistics to yourself.
Old 06-08-2010, 09:43 PM   #70
JAGNZ
Originally Posted by Helico-pteron View Post
You can use the R617FS at 8.4V.
Someone needs to tell Futaba that, they say 6v MAX:
Jason Greenwood
www.3dheli.co.nz
Old 01-22-2011, 03:28 PM   #71
Al Miessner
700 LE
Align 91 w/ align pipe
GY 701 Gyro/gov w/ BLS251 on tail
Herculese 10 amp Regulator 6V
DS610s on cyclics
DS620 on throttle
remote switch glow.
on Bad A$$ combo.
Flying Hard makes it fun (AnimAL)
GrandRC Team Pilot \, Team Ninja Pilot
Al Miessner is offline        Reply With Quote
Old 01-23-2011, 09:35 AM   #72
Matt Nasca
Align Trex 700N
OS 91 HZ-R
Hatori SB-20FH-2
Rotor Rage 30% Masters
Vbar 5.0 Pro - Spektrum Satellites
Gryphon Extreme Heli Voltage Regulator
Push-Glo
DS610
BLS251
KDE FBL head
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote
Old 01-28-2011, 10:39 AM   #73
Love_Heli
T-REX 700LE
ALIGN 91H
HATORI PIPE
MIKADO V4.0 SPEKTRUM AR700
ALIGN 2 in 1 Voltage Regulator
CYLIC FUTABA BLS-451
RUDDER FUTABA BLS-251
RJX FBL HEAD
VŨ NGUYỄN
Gaui NX7 OS-105 HZ-R - HATORIES PIPE - MKS950HV - MKS980HV - MIKADO V 5.3 PRO
Gaui X7F K160 - SCORPION HK-4530-540KV - MKS950HV - MKS980HV - MIKADO V 5.3 PRO
LOGO 690SX JIVE PRO 120HV - MKS665HV - MKS669HV - MIKADO V 5.3 PRO
Love_Heli is offline        Reply With Quote
Old 02-15-2011, 10:16 PM   #74
just4fun
Default new ys
im running the new ys its insain
just4fun is offline        Reply With Quote
Old 03-09-2011, 08:48 PM   #75
ualdrivr
Just converted my trusty old 91 HZ to HZ-R. Haven't even started it yet.
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 04-07-2011, 09:57 PM   #76
Chaos 5
T-Rex700N
3 X BLS451
Rudder is a BLS251
DS650 for Throttle
CGY750 FBL
Radix 710's
Futaba 3Ch RX
NRG 3600 2s
Align 2 in 1
OS91 HZ-R
Hatori SB20 pipe
RR 30%
Loving every minute of it .
Chaos 5 is offline        Reply With Quote
Old 04-10-2011, 10:12 AM   #77
Chris Lalonde
Just finished the build on my 700fbl
OS91 HZR
Mp6
Vbar 5.1pro
610's on cyclics
savox 1258 throttle
bls251 for tail
gyrphon reg for now
vbar gov with spektrum sensor
Align main and tail blades
futaba 8FG radio
Futaba 6203 SB rx
still doing radio work and setup but hope to have it in the air soon
Chris Lalonde is offline        Reply With Quote
Old 04-19-2011, 07:46 PM   #78
elkmaster01
Any help?
Those Align 'step down' regulators won't do what you are planning. Those step down the voltage from a regulated 6V to 5.1V. Meaning they only reduce the voltage by about .9V. When hooked up to a 2S lipo they only bring the output voltage down to about 8V from the 8.4V lipo.
elkmaster01 is offline        Reply With Quote
Old 04-20-2011, 01:19 PM   #79
ntwaddell
Align Trex 700N
OS 91 HZ-R
Hatori SB-20FH-2
Kasama Header
Vbar 5.1 Pro
SG Reactor X2
SwitchGlo Pro
Goblin Urukay Competition
Align T-Rex 450 Pro FBL
Align T-Rex 700 Nitro FBL
dji F-550
ntwaddell is offline        Reply With Quote
Old 04-25-2011, 12:58 PM   #80
CoolKD
Trex 700LE
3xDS610 cyclic
Align GP780 gyro(gonna get a Futaba GY701 gyro and gov with a Futaba BLS251 servo for the tail)
2xDS650 tail and throtle
Align GOV
Align 2 in 1 power regulator
Spektrum AR7000 reciver
Stock paddles
Stock Main blades Align 690D
Stock tail blades.
Align 91.HP(OS91.HZ)
Align pipe
2S LiPo 5000mAh 25C(forget the brand)
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
CoolKD is offline        Reply With Quote
