Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-25-2011, 01:24 PM   #81
backburner1955
Align T-Rex 700 Nitro Pro Limited Edition
Align 91HP Motor
Align 90 Muffler
Spektrum AR7100R
Perfect Regulators Spekline 6.5V Regulator
3- JR8717 Cyclic Servos
Align DS650 Tail Servo
Align DS620 Throttle Servo
Align 690D 690mm Carbon Fiber Main Blades
Align 105mm Carbon Fiber Tail Blades
MicroBeastX Flybarless Controller
Align 3G Flybarless Head
Seacraft 70mm Pitch Link Turnbuckles
Align Aluminum Elevator Servo Bracket
KDE Performance Tail Upgrade
Align Carbon Fiber Tail Control Rod
RC Booya Extreme Canopy Mounts
Align 700 Black landing Gear Struts
Byron's Rotor Rage 30% Masters
2- 2S 3000mah 30C RX LiPos
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Reply With Quote
Old 04-26-2011, 01:34 AM   #82
onequick96gt
650 flight old heli, better late then never ha.
700 LE converted to fbl with new style head and short shaft
YS 91SR-3DS (Enya 4)
Hatori SB-19 (-2 header)
8917hv's cyclic
BLS 251 tail
Microbeast
7100r
2s lipo for straight 8v setup, BeastX wired stock, power for tail servo comes from rx 5.2v
Switchglo pro
Mavrikk 690 fbl "redlines"
Align 105 tails
RC Booya quick release mounts
quick UK tail boom clamp (broke off 2 tail booms with stock one, lol)
Aaron Johnson
Synergy/Botos Design and Distribution
YS Engines/Hatori
Byron Rotor Rage
onequick96gt is offline        Reply With Quote
Old 05-08-2011, 08:52 PM   #83
haha
trex700 fbl
KDE upgrades
KASAMA bearing blocks
tail is all metal
YS91 sr 3ds and fh sb19-2
8717 HV on cyclic
8900g on tail
microbeastx flybarless sytem
ar7100R with dx7se
1.0 main gear mod
ds620 on throttle. everything is metal.
haha is offline        Reply With Quote
Old 07-22-2011, 08:30 PM   #84
aviator493
Trex 700N FB
-OS 91HZ-R
-Hatori FB-20
-Cyclic BLS451
-Rudder BLS251
-Throttle DS650
-Scott Gray Reactor 2
-Push Glo
-GY701
Trex 700N FBL
-OS 91 HZ-R Speed 3D
-Hatori FB-21
-Cyclic BLS451
-Rudder BLS251
-Throttle DS650
-Push Glo
-CGY750
aviator493 is offline        Reply With Quote
Old 07-22-2011, 08:49 PM   #85
dchekas
T700N LE FB
-OS 91HZ-R
-Funtech B301
-BLS451's on cyclic
-BLS451 on throttle
-DS650 on tail (until BLS256HV is out...)
-GY701 Gyro/Governor w/ BPS-1
-SwitchGlo Pro
-6108SB RX
-Pulse 3600mAH LiPo
-RC Booya Canopy Mounts
dchekas is online now        Reply With Quote
Old 12-19-2011, 06:03 PM   #86
nightrider
Trex700n FBL
Donk - Align 91h
Muffler - Align
Gyro - TT GT5 fbl
Cyclic servos - JR 8915HV
Tail servo - Align DS650
Throttle servo - DS620
Governor - Align
Regulator - Perfect regulators, Flex reg pro
switch glow pro
Blade Mcpx
Align Trex450 se/sport
TT Raptor Titan
Align Trex700n FBL
nightrider is offline        Reply With Quote
Old 01-20-2012, 09:41 PM   #87
gnirwin
Default My Setup
Cyclic Servos: Align ds620
Tail Servo: Futaba BLS251
Gyro: Futaba CGY750 w/governor
Blades head: Mavrikk G5 pro
Blades tail: Stock
Engine:OS 91HZ
Pipe: Align
Receiver: r6208SB
Onboard glow: Align w/ regulator
Radio: Futaba 8FGA
gnirwin is offline        Reply With Quote
Old 01-21-2012, 04:56 AM   #88
NitroAl
700N FBL
OS105HZ-R
OS powerboost
Cyclic-JR DS8915 (US DS8717)
Throttle-Spektrum H6040
Rudder-Outrage Torq BL9188
Mikado VBar with Spektrum satellites.
Scott Gray Reactor X2 @ 6.8v
Perfect regulators switch glow
Kongpower 3600mah 2s LiPo
JR 11X
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 02-21-2012, 04:27 AM   #89
Marek1
Default Trex700 "power systems"
700N FBL
YS Yamada 120SR
Hatori SB-23 for YS120FS-3D
Cyclic - Outrage BL9080
Trottle - Futaba S9254
Rudder - Savox SH-1290MG
Mikado VBar 5.2 Pro Spektrum satellites
Just-Heli JH 20A PRO Voltage Regulator
EDGE 693mm SE Premium
EDGE 105mm
DX7 se
Marek1 is offline        Reply With Quote
Old 02-21-2012, 07:38 PM   #90
hakulhak
700N FBL with 800mm tail boom
YS 91SR 3DS (14 gallon still running strong)
Funtech B300 90 Type X3D
Cyclic ; Align DS610
Throttle : Align DS610
Rudder : JR8900G
Futaba CGY750
Perfect Regulator Flex Reg Pro
SAB 710mm 64mm
Edge 115
Futaba 8FGS
Align T-Rex 250/Align T-Rex 450 Pro/Winrc 450DT/Align T-Rex 600N Pro/JR Vibe 50/Gaui X7/Align T-Rex 700N DFC/Align T-Rex 800E DFC/Align T-Rex 800E Pro FL
hakulhak is offline        Reply With Quote
Old 07-14-2012, 12:06 PM   #91
K24Tyler
Os91hz-pumped viper head
Outrage pipe
beastx
DFC head
Team Synergy
Rail Blades
8fg
K24Tyler is offline        Reply With Quote
Old 02-19-2013, 06:49 PM   #92
funnelcake1999
Does anyone know of a DLE 20cc in a trex 700. and what conversion kit is required? Thanks.
funnelcake1999 is offline        Reply With Quote
Old 03-12-2013, 12:53 PM   #93
Frankcm1
Trex 700N
OS91SZ w/Modified Muffler
Align DS615 (3)
Spektrum S6040 throttle servo
Futaba BLS251 Rudder servo
Skookum SK540 FBL Controller
Zippy Flightmax 2600mAh LiFe RX pack
Align 3G main blades
Align 105mm tail blades
DX8 TX & DSMX SATS
_________________________________
Trex 700N,600N,700e DFC, Fusion, Goblin500, Blade450x, Helix G700(in progress)
Frankcm1 is offline        Reply With Quote
Old 07-09-2013, 02:28 PM   #94
schneids
I've never met a heli I couldn't crash.
schneids is offline        Reply With Quote
Old 07-10-2013, 01:19 PM   #95
mamartin
TREX 700N DFC
YS 91SRX
HATORI SB-19FH-4
JR 8717 cyclics
OUTRAGE TORQ 9188 tail
EDGE 693se
ALIGN 105's tail
iKON Flybarless system. Using iKON governor as well
2 Spektrum DSMX sat's,
JR 11X
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote
Old 11-10-2014, 10:54 AM   #96
Baedarlboo
A little late to the game but...
Trex 700N LE converted to DFC
OS91SZ
FunTech B301
Align BL700H (3) cyclic
Align BL700H throttle servo
Align BL750H Rudder servo
AR7200BX FBL Controller utilizing built in nitro governor
5000mAh 2s LiPo direct connection
SwitchGlo
RJX main blades
DX8 TX & DSMX SATS
Baedarlboo is online now        Reply With Quote
Old 12-01-2014, 01:27 AM   #97
Copterdoc
Trex 700N pro with kde non DFC head.
Lynx ultra dampeners
OS 91HZ-R
Hatori SB-20
Dual Plug Head OS#8 and OS #6
Bladder mod
BK servos (coreless)
Spartan Vortex vx1n
Optipower 2150mah rx pack
SAB 690 blackline 3D blades (blue)
SAB 115 blackline tail blades (blue)
KDE upgraded tail and DFC tail upgrades.
VP/Powermaster 30% fuel
Still rich on new engine break in and it's a rocket! Can't wait to see what it will do tuned up and ready to rock!
Greg "G-dog" St. John
Team Lowerheli.com
Team Optipower USA
Team Powermaster VP Racing Fuels
Copterdoc is offline        Reply With Quote
