Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Whiplash
MA Whiplash Miniature Aircraft Whiplash Helicopter Support Forum
Old 04-04-2014, 12:14 PM   #61 (permalink)
The -17 gears are pretty simple to make with a lathe and mill. Enclosed are pictures of the process I used. I CA glued a 3/8" aluminum shaft to a bored out blank. I then drilled a 6mm hole in the gear / shaft assembly. Next I counterbored, drilled and tapped the gear / collar. I installed the set screws, put the assembly back in the lathe and cut it to the proper length. I then used a high tech bandsaw to cut the gear loose. Back to the lathe to clean up the cut.
ID:	499988   Click image for larger version
ID:	499989   Click image for larger version
ID:	499990   Click image for larger version
ID:	499991   Click image for larger version
Arrow2 is offline        Reply With Quote Quick reply to this message
Old 04-04-2014, 02:57 PM   #62 (permalink)
Looks pretty good to me...
How long to make one do you think?
---- JR Vibe SGE12 Hiroki Ito Scorpion Tribunus 200A 4525 Ultimate Spirit FBL—-Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL --- RJX Vector 700 Pyro750-56 Comp Kosmik 200 ——
malc1 is offline        Reply With Quote Quick reply to this message
Old 04-04-2014, 03:29 PM   #63 (permalink)
It took about an hour to make 5 good ones and 1 goof. If you want 1 or 2, let me know.
Old 04-04-2014, 04:15 PM   #64 (permalink)
Thanks for the offer but luckily I'm OK at the moment for these gears (have 4 131-17 and 2 black 131-17B)
I pretty sure there must be guys out there totally stuck though.
Just for information,what you going to sell them for?
Old 04-04-2014, 04:23 PM   #65 (permalink)
I would like to recover the cost of materials, so I was thinking $5.00 plus shipping. This is a hobby for me, not a business. Also, I can't mass produce these, but would be willing to help those in a jam.
Old 04-04-2014, 04:36 PM   #66 (permalink)
Excellent!
Old 04-05-2014, 01:27 AM   #67 (permalink)
Default Re : Whiplash Aftermarket support
Hi,
Is it possible to buy 5 of the 131-17 ?
And the 131-18 could you have them?
Regards,
Joël, from France
Envoyé de mon SM-N9005 en utilisant Tapatalk
raptor90se is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 04:37 AM   #68 (permalink)
Whoa. I received some pm's for parts as well as your request. I have already sold 4, so at the moment I have 1 left. I will make some more this weekend. Why do need (want) 5? I don't want to turn this into work, As far as -18's go, I don't have the right size endmill at the moment for a proper fit.
Mike
Old 04-05-2014, 08:00 AM   #69 (permalink)
Thanks Arrow , thats cool that you can make the gear . 5 gears really? He did say he is not looking to turn it into a job and just to help somebody in a bind. Hopefully Ron lund can get some gears made, that way he can make some money off the prepers.
MSH mini-p VBar ,G380, Goblin 500, TREX 600N LE VBar, Trex 700N 91hz FB, Whiplash 105HZR VBAR, Nitro Citizen 414
mr008 is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 03:50 PM   #70 (permalink)
Wow Arrow2 - impressive stuff, nice work!
I got really lucky and managed to get a 17 and 18 in the UK from Motors and Rotors but that's all he had. I got a few flights today and on the 3rd flight the tail let go and it started pirouetting. Luckily I wasn't doing anything wild and just flying around and had plenty of time to hit throttle hold and land safely. Having had a quick google, it looks like mine has the old style pitch slider and and threaded brass piece had split at the threaded section. I'm sure I should be able to find the later parts to fix but Dave at Motors and Rotors told me to bring it in and if he doesn't have the parts we might be able to machine something up. I bought the machine used (but hardly flown at all) so I guess the original owner just missed the upgrade notice on the slider.
Andrew Bird is offline        Reply With Quote Quick reply to this message
Old 04-10-2014, 02:15 AM   #71 (permalink)
Check that forum one more time Gents.... Plenty of Parts to keep 'em flying...
Doctorfixjet is offline        Reply With Quote Quick reply to this message
Old 05-11-2014, 03:48 PM   #72 (permalink)
Hi
do we have a solution to make compatible main gears 131-1 ? Or know of a shop that still have a couple of them.
the counter bearing of my elec whiplash broke and the pinion partially stripped the main gear. I will use my last main gear I bought as spare parts, and will be short on them next crash ...
steph, from France
steph66 is offline        Reply With Quote Quick reply to this message
Old 05-14-2014, 09:58 AM   #73 (permalink)
Hi steph
I can check with my LHS if they have them If you like.
I just ordered new tailgears, and som shafts, boom etc. from them, so it seems they have a lot of whiplash parts in stock.
/Christoffer
www.helistore.se
Mikado SAB Kontronik Scorpion dealer, so I might be a bit biased.
christoffer is offline        Reply With Quote Quick reply to this message
Old 05-15-2014, 01:35 PM   #74 (permalink)
thx christoffer, I found a couple on the web.
Just wondered if we have a solution for when there will be no main gears anymore. Can we find a compatible spare part ?
Old 05-16-2014, 05:08 AM   #75 (permalink)
Default Replacement Parts
Has anyone looked at 3D scanners and printers as I think we will see some huge changes, making these very accessible to the home user
gregmorris is offline        Reply With Quote Quick reply to this message
Old 05-16-2014, 08:14 AM   #76 (permalink)
Its a good idea to make good dxf-scans of the parts, like frames and such..
But gears, i think its to possible to get the local machine-shop cut gears for us, but quite expensive, maye some other manufacturer has similar gears and other parts we can modify for the whiplash.
www.helistore.se
Old 05-16-2014, 08:39 AM   #77 (permalink)
The main gear was a special gear MA made. A local shop could copy them, but it would be expensive in low quantities. The main gear materiel is very critical, it must be strong and have some lubrication properties.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is online now        Reply With Quote Quick reply to this message
Old 05-19-2014, 03:47 AM   #78 (permalink)
Hi Tom,
For the maingears I suggest Delrin (Polyoxymethylen). The Whiplash maingear seems to be made of it too.
As for the frames, the left frame would do. Can be used to replace the right frame, so there would be only one design to cut. I started out to model it in a CAD. Will still take time to finish, I am quite busy at work and it is (finaly) flying-season too:-)
If the left frame is to be used as right frame too, it has to be more stable. I think of changing is a bit to give it more strength. For example, The front-mounting for the landing gears seems vulnerable. Especially with the hole for the switch right above.
Where does the left frame usually break? What are the weak spots? Any experiences?
Kind regards
George
OldGasser is offline        Reply With Quote Quick reply to this message
Old 05-21-2014, 04:14 PM   #79 (permalink)
Tail drive gear ma131-15.
I see the blade 700x runs a 27t tail drive gear. Does anyone know weather they would fit the whiplash?
Here is a link http://www.rcplanet.com/Blade_Tail_P..._p/blh5738.htm
They look similar.
Chicko is offline        Reply With Quote Quick reply to this message
Old 05-22-2014, 11:38 AM   #80 (permalink)
Hi Chicko,
From the 700x manual I conclude that the gear has only a 5mm bore while the Whiplash has 6mm. Also the gear is secured by a pin, while the Whippy uses two setscrews.
IMO, the gear A 1Z 2MYZ1002706 from sdp-si.com is the easiest way to go. I ordered one to check and it is almost identical. It has a brass insert which is prefferable to acetal only for setscrews. You will only have to tap a hole for a second setscrew. Stock it only comes with one, which I would not want to rely on. Maybe grind off a little from the hub. That's it.
Kind regards
George
