Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 05-26-2014, 12:25 PM   #1 (permalink)
Default Do I need VBar adaptor for Ikon gov w/YGE?
Gents,
Going nuts trying to get the governor in my Ikon and 120 YGE setup. I have gone through all the videos, read every thread I can find and still can't seem to get it right. Both the Ikon and YGE have been calibrated with the throttle and all worked fine with just basic throttle curves. I have noticed that if I disconnect the short cable from the YGE and the Ikon governor cable, the ESC will arm normally (though it won't run), but when I have the short cable/gov lead connected, the ESC just glows bright orange, indicating it is not seeing low throttle.
I found one thread that indicates that I might need to make a vbar adaptor cable, even with the Ikon. Is this true?
Getting to the point of just going back to throttle curves, which seemed to work fine.
Thanks!
D.W.
DWSchmidt is offline        Reply With Quote Quick reply to this message
Old 05-28-2014, 09:22 PM   #2 (permalink)
For anyone who stumbles across this in the future...apparently the answer is yes, I do need the adaptor cable to hook the Ikon up to the YGE and use the external governor. I'll give it a try and hopefully that will solve all my issues.
D.W.
Old 05-29-2014, 02:24 PM   #3 (permalink)
errr... I have the same setup - Ikon with YGE 120 HV on my Goblin 570 and all I needed was the Hobbywing Phase sensor connected between the Ikon and two lead off the motor.
dyuen888 is offline        Reply With Quote Quick reply to this message
Old 05-29-2014, 03:38 PM   #4 (permalink)
You don't need a ext phase sensor with YGE. They have one built in. You just have to wire it right. There's a difference in how you wire a HV and LV.
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 05-29-2014, 05:01 PM   #5 (permalink)
I'm using the 120LV with ikon with no issues on my HD 500 cell , 40+ flights , programmed the YGE with the vbar program ( 3x gov off ) , yes using the build-in phasesensor
here I'm testing the gov
ikon gov testing (3 min 17 sec)
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 04:14 PM   #6 (permalink)
Ok, so what's this magic secret Ikon-YGE governor adapter to make the YGE's vbar-compatiable gov output work with the Ikon???
Any links? Videos? Schematics? And is this only for YGE HV's or all YGE or what? Do share
mcpx BL, 180cfx, 450 X, 500 X, Logo 480xx, Gaui X3, X5, Protos 500, HD Cell 500, phoenix, RF7
helirifick is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 05:03 PM   #7 (permalink)
You only need the cable on the HV version.
Heli's I have:
Old 07-01-2014, 05:05 PM   #8 (permalink)
Heli's I have:
Old 07-01-2014, 05:27 PM   #9 (permalink)
That's a big honking capacitor there -- you building a railgun for your heli??? LOLOLOLOLOL
Ok, so this adapter cable is only for YGE HV versions, which are opto-isolated. It looks like you took a YGE opto cable and joined ground and signal together and ran that to one pin on a JR connector and red cable to another JR pin, thus the 2 pins input to the Ikon gov adapter cable? Is the red cable carrying throttle signal -- 'cause on YGE HV's it doesn't have a BEC, so it's either throttle or used for programming?
thanks
Old 07-01-2014, 05:54 PM   #10 (permalink)
On HV's the red wire carries the rpm signal. You have to join the ground and signal wire together to prevent noise on the red wire.
Heli's I have:
Old 07-01-2014, 05:55 PM   #11 (permalink)
The cap is for my 700. I use a WR super mini g2 but the cal helps.
Heli's I have:
Old 07-01-2014, 06:04 PM   #12 (permalink)
I wired mine up today... It works fine on the bench with the blades off...
Brain gets rpm reading, governor works fine as does my bailout.
going to test in on the field tomorrow...
see the pic.
It may no be too clear to see, the red cable is soldered to the grey cable going into the Brain gov port and the black cable is soldered to the black cable going into the gov port.
ESC is: YGE 160HV
T-Rex 250 pro DFC w/ BeastX - T-Rex 500FBL w/ BeastX - MD7 w/ Brain FBL - T-Rex 700E Pro DFC w/ Brain FBL
JHuygen is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 06:35 PM   #13 (permalink)
Op is using LV ESC's. Does not need that cable.
Heli's I have:
Old 07-01-2014, 06:51 PM   #14 (permalink)
I'm sorry ;-)
I read something about a HV YGE so I thought i'ld chime in. Just my 2 cents.
It's late here in Belgium, almost 2 AM and we just beat USA in the Fifa Worldcup LOL
Old 07-01-2014, 10:05 PM   #15 (permalink)
Actually I was talking about the HV version of the controller, but realized I never actually said that. I ended up making the adaptor cable and with no other changes I was able to get the ESC to arm. Unfortunately, I've been so busy with other projects and work that I haven't gone any further then that. Hopefully next weekend I'll get some time to try it all again and see if I can make it work.
D.W.
