800 Class Helicopters 800 Class Helicopters |
12-01-2014, 03:50 AM | #1 (permalink) |
What batteries are you running
can some of you tell me which batteries are you running on an align 800e.
the make and ah etc, as much detail as possible on the make numbers. and how many are you running, 1 battery or two I also have the same question in the 700e series in that section thanks for any info. |
12-01-2014, 07:11 PM | #2 (permalink) |
On my 800 Trekker, I'm running Glacier 5300mah stick packs - two 6S packs made into one stick by BuddyRC.
12-01-2014, 07:58 PM | #3 (permalink) |
What flight time you're getting?
X7F#1-Xnova 4530-525, HW 160HV V4, MKS X8 Servos, Mini Vbar X7F#2-HK4525-520 LE, HW 160HV V4, MKS X8 Servos, Mini Vbar |
12-02-2014, 04:26 PM | #4 (permalink) |
Been using Revolectrix HV 5500 - so far so good. Cheap to at $99usd each.
Also use Gens Ace 5000 60c, rock solid so far - more confidence in these than the revo's, just a bit more pricy. Used on a Trex 800Pro with XTS-4535-460 motor. Sent from my iPad using Tapatalk
Diversion 760, Specter 700, Oxy5, TDF, Kraken, Logo600, Dune 600, Vcontrol Touch 3DME Alloy Vtouch Design Team - https://3dminiatureengineering.com/p...m-case-upgrade |
12-02-2014, 06:27 PM | #5 (permalink) |
I'm getting 10 minutes of sport flying, headspeed around 1750 - 1800
12-02-2014, 08:36 PM | #6 (permalink) |
Spyder packs here.
12-03-2014, 12:29 AM | #7 (permalink) |
Align 5200 mah 65c
Pulse 5500 mah 65c and Pulse 5500 45c I usually run them for 5 minutes and put back between 3000 and 4000 mah depending on the flying style. Ive also put 2 of the 5500's in parallel and had it in the air for about 15+ minutes.
Trex 800 DFC Pro Goblin 700 Competition Trex 600 ESP FBL - R.I.P. MSH Protos 500 |
12-15-2014, 09:49 AM | #8 (permalink) | |
