Go Back   HeliFreak > R/C Electronics Support > Spartan RC
Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support
Old 03-07-2010, 01:04 AM   #1121 (permalink)
Originally Posted by Dumb Thumbs View Post
I'm searching around gyro threads looking for ideas for what I want to put on a new 450 I'm building. Man, this DS760 looks like a lot to be messing with.
Is it really worth all the trouble?
This has to be one of the easiest gyros to setup.
I am running one on my 600 and it took me all of 3 min to setup when I first got it.
Read the manual, it's super easy. I have a 2100T on my 450 and it takes 20 min but the time you mess with all the stuff you have to setup.
Trex 600E FBL....Trex700DFC...Trex700FBL
more to come.....
crashagain is offline        Reply With Quote Quick reply to this message
Old 03-08-2010, 06:48 PM   #1122 (permalink)
*ZFG
Youtube
AzHeliCrasher is offline        Reply With Quote Quick reply to this message
Old 03-08-2010, 07:22 PM   #1123 (permalink)
*ZFG
Youtube
Old 03-08-2010, 10:02 PM   #1124 (permalink)
I don't know about your servo but I noticed this on the website.
NOTICE: To be used with Futaba 600 Series Gyros Only
The blinking lights represent the frame rate the servo is capable of. I know that 2 flashes mean a 333 frame rate like that of a JR8900
Try 3 flashes and see what happens.
If you go to Spartan's site, there is a chart that will tell you what servos will work and what the setting on the gyro should be.
more to come.....
Old 03-09-2010, 03:20 AM   #1125 (permalink)
AzHeliCrasher,
Please see the firmware release notes which provide details on what has been added and changed. I believe you will find the answers you need there.
http://www.spartan-rc.com/resources/...=67&category=5
http://www.spartan-rc.com/resources/...104&category=5
-Angelos
SPARTANRC - R&D
Angelos is offline        Reply With Quote Quick reply to this message
Old 04-23-2010, 07:17 PM   #1126 (permalink)
I am catching it with a DS760 and a Futaba 7C. I don't have the USB cable so I have to do radio set up. Can't get it to setup for the life of me.
Perfect practice makes perfect
leejax01 is offline        Reply With Quote Quick reply to this message
Old 04-25-2010, 07:46 AM   #1127 (permalink)
What exactly are you struggling with regarding Tx setup?
450 PRO, 500 ESP
Due to economic circumstances, the light at the end of the tunnel has been turned off until further notice.
lankey is offline        Reply With Quote Quick reply to this message
Old 04-25-2010, 11:29 AM   #1128 (permalink)
Setting it up with the TX is easy. I just setup a new one last night. Took about 3 minutes.
What can't you get setup right?
more to come.....
Old 06-11-2010, 01:23 PM   #1129 (permalink)
:YeaB aby:
helifreaker123 is offline        Reply With Quote Quick reply to this message
Old 06-15-2010, 05:22 PM   #1130 (permalink)
is there any way you can help me figure out a futaba 520. i have tail wag and it is on a trex 450 se v2. I hate this gyro so far I can not find any one who can help me.
flynandy1665 is offline        Reply With Quote Quick reply to this message
Old 06-15-2010, 07:24 PM   #1131 (permalink)
Wag is usually the gain is too high, or you have something sticking in the tail movement.
Also it could be you have the ball link too far out on the tail servo. They like to be close for the best resolution. On a 450 size it should be around 6 to 8mm from center.
What radio are you using it with?
more to come.....
Old 06-23-2010, 05:50 PM   #1132 (permalink)
Default Servo menu access with a Futaba 10ch TGY-930 on 500 heli
I have not been able to get to the selection menu for the gyuro set-up. I power on the Tx, then power the heli with left rudder input while switching between Norm/AVCS modes. Once fully powered the light is solid in AVCS and off in Normal mode. I can push rudder to the left and I get two blinks. I can not get the two blinks to change to 1 or 3. I am using a Turnigy TGY-930 servo on the tail of a 500 heli. Any help? Not sure which mode to use, but it does not seem to be working for me properly.
Kenny
tahoelight is offline        Reply With Quote Quick reply to this message
Old 06-23-2010, 08:56 PM   #1133 (permalink)
I would try 3 flashes, the servo looks like the hyperion type servo, but I can't find any specs on it other then speed and voltage.
Sometimes all you can do it experiment.
more to come.....
Old 06-24-2010, 12:46 AM   #1134 (permalink)
Thanks for the tip, only problem is, I can't seem to get it into setup mode to select the number of blinks. I have tried to follow exactly what the directions say, but can't make any changes.
Kenny
Old 06-24-2010, 12:49 AM   #1135 (permalink)
I have one that is a little fussy too. Just keep trying, hold the rudder stick to the left and and toggle the gear switch, once your in, move the rudder stick, don't hold it long. The trick is to give it a quick stab to the left or right to select your setting.
more to come.....
Old 06-28-2010, 01:59 AM   #1136 (permalink)
I have a question about the firmware update to my DS760. I just got the FlashLink cable and was reading some notes on the Spartan website when I saw this:
" Removed "wait on rudder". The gyro will no longer wait until the rudder stick is centred. Spektrum users should bind their receivers while the rudder is at mid-point."
So, does this mean I should re-bind my DX6i? I used the "bind off center" trick as per the instructions when I set up the gyro. Do I re-bind with the stick at center now? Thanks.
If you can't learn to do something well
Learn to have fun doing it poorly
Ian
MrWolf is offline        Reply With Quote Quick reply to this message
Old 07-10-2010, 12:25 AM   #1137 (permalink)
Default is there a difference ?
I don't get it? Is there a difference in the ds 760 and the Quark? why is one (ds 760) a smm and the (quark ) a mems, if this is the difference then what does that mean?----> and if the quark is newer and mabey better , then why is the ds 760 still cost more?---> ok ok, i didn't realise this was happining, but
ball link is offline        Reply With Quote Quick reply to this message
Old 07-11-2010, 06:40 PM   #1138 (permalink)
Just throwing this one out there, but the new v2.0 firmware in the ds760s do not require the left stick input to enter setup.
Insert a bind plug into the gyro, then power on to enter servo selection mode....
Power on the gyro, THEN insert the bind plug to enter gyro setup mode.
Makes life alot easier... my manual did not reflect this. ALSO use the Quark manual for servo selection because there is now a 4th mode for servos.
AMA# 655558
Trex 600E, Compass 6HV FBL Head, Microbeast, Inolab DS760MG cyclic, Logictech 6100G tail, CC HV85 ESC, Scorpion 4025-630
briangp is offline        Reply With Quote Quick reply to this message
Old 07-23-2010, 05:50 PM   #1139 (permalink)
The guy said use JR DS8900G settings for Align DS650 , and it works much better, then "generic" , i dont know how but it is true.
This is true??.
And better used gyro sens or ATV for gain in DX7 ??
I have a question about the firmware update to my DS760 2.01, The new defaults setting change compare to the last firmware is better or not than 2.00, or better use the old setting??
Fune is offline        Reply With Quote Quick reply to this message
Old 09-15-2010, 09:45 AM   #1140 (permalink)
I have a question. I have set the 760 on my trex 700. It had been doing just fine until a couple of weeks ago. I had rebound and set up the 760 after a crash and when I went to lift off, the gyro was reversed. I figured that I had bound incorrectly. I went back to setup the gyro again, doing endpoints and gyro correction direction. Went to lift off again, same thing, it started spinning. For some reason, the direction was not saving correctly, so I ended up reversing the rudder on my dx7, went into setup again, setup using the reversed direction, switched the rudder on the dx7 again and flew. It flies fine, but I am wondering why is this happening? I am setting up according to the videos, and had set it up fine before. Also, when I am setting the direction correction in setup, the slider is moving correctly. When I turn the helicopter off and back on, and swing the heli, the direction is again wrong.
LFRyder is offline        Reply With Quote Quick reply to this message
