Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 11-05-2011, 07:45 PM   #1 (permalink)
Default E7 CRASH - Belt Snapped
My belt snapped on my during flight this morning. Heli only has about 10 flights on her. Very disappointing
Maybe a defect/manufacturing flaw...Other's please be cautious and check your belts. Brand new Rail 696 blades & 106 tail blades are ruined + the canopy. Pics are attached.
ID:	264963   Click image for larger version
ID:	264964   Click image for larger version
ID:	264965   Click image for larger version
mstlc03 is offline        Reply With Quote Quick reply to this message
Old 11-05-2011, 07:46 PM   #2 (permalink)
Default Continue
More pics...
ID:	264967   Click image for larger version
ID:	264968   Click image for larger version
Old 11-05-2011, 07:49 PM   #3 (permalink)
To bad, I have 52 flights on my E7 and don't have one problem. Check to see if the bottom tail spacer has the flat spot facing up.
Team Rail blades,
Team Scorpion motors,
V-Team
ClubCRASH is offline        Reply With Quote Quick reply to this message
Old 11-05-2011, 09:18 PM   #4 (permalink)
Check your idler pulley on the tail case. I had the bolt and locknut too tight and it want spinning. I was lucky and figured it out with the help of some fellow freaks before I burned through it.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 11-05-2011, 09:48 PM   #5 (permalink)
Thanks for the tip. I found out early on that I had to losen the bolt for the pulley. As you said, that pulley get too tight with the nut screwed down all the way...
Old 11-06-2011, 08:44 AM   #6 (permalink)
also check your tail stops %, you may want to tone them down a bit. The belt is fine, if you don't do hard tail stops or lots of piros against torque and at high pitch.
Aslo make sure you don't have less than 3mm left on the rear boom clamp.
4cyclic is offline        Reply With Quote Quick reply to this message
Old 11-06-2011, 09:02 AM   #7 (permalink)
I hope this is not a true statement? I would think that the belt on the e7 could handle aggressive stops.
I thought I heard in a podcast that there will be an optional TT upgrade eventually? Not that I think it's needed, just want to know the options.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 11-06-2011, 09:26 AM   #8 (permalink)
Its a 3d Heli...! we wont do Hard Stops..! thats crazy...! It was a defect from the manufacturer for sure..!
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 11-06-2011, 10:11 AM   #9 (permalink)
Agreed, manufacturer defects happens every day. Not trying to push blame but want to ensure that Synergy investigate to ensure this is not a common theme as this one caused me dearly!
Old 11-07-2011, 09:56 AM   #10 (permalink)
Guys,
I will do some further investigation on this to make sure this is not a manufacturing defect.
Yes, there is a TT system coming for those that prefer. I will hopefully have a conversion kit ready for Christmas.
Thanks,
Matt
00boto is offline        Reply With Quote Quick reply to this message
Old 11-07-2011, 01:59 PM   #11 (permalink)
Add me to the list of belt snappers. Fortunately, I was able to auto it down safely. I'm sure these are isolated incidents but I am glad the TT will be an option. Hope it doesn't add alot of gear noise cause I love the stealthy sound of the Helical gears and the belt drive.
Matt, can you share whether the counter gear for the torque tube will be a delrin helical cut gear?
don-dadda is offline        Reply With Quote Quick reply to this message
Old 11-07-2011, 07:14 PM   #12 (permalink)
Don-Dadda,
Your belt snapping was likely related to the abuse it went through at the VA Heli invasion. The boom supports not being glued was causing your belt to tension and untension very rapidly. That coupled with the slippage you were experiencing took a serious toll on the life of your belt. If you let the belt skip teeth it will eventually break. Now that your helicopter is setup properly you will likely have success.
TT System -
I have flown the new system multiple times now and it is very quiet. I did not like the idea of helical cut on the counter gears due to vertical movement as well as a much higher cost on a gear that is expendable in a crash. Im trying to maintain a high quality helicopter that is still reasonable to repair. I did chose mod 1.25 gears on both bevel gears and counter gears for durability. I have tried to break them over the last couple days with ridiculous reversal torture and they showed no signs of stress.
Two Chinese Team Synergy pilots competed in China 3DX over the weekend. One pilot placing 3rd in the sportsmans class using a belt driven E6. The other pilot placing 3rd in the expert class was flying an E7 with the new shaft driven tail. Many watching the competition could not tell the sound difference between the belt E6 and the shaft driven E7.
Matt
Old 11-07-2011, 07:32 PM   #13 (permalink)
Matt, good to know about the TT option. I guess is it wise at this point to not fly my E7 until the TT option is available? Not knowing why my belt snapped (and it's not from abuse <g>) really scares me. I cannot afford to keep replacing blades and canopies. Your advice is appreciate it.
Old 11-07-2011, 09:25 PM   #14 (permalink)
Originally Posted by 00boto View Post
Don-Dadda,
TT System -
Matt
Hi Matt,
How much weight does the TT conversion add?
Old 11-07-2011, 09:30 PM   #15 (permalink)
Matt,
I think your mistaking me for Zack. This is Patrick, skyfoxsxer on runryder and on your forum. I did have belt slipping problems but it was not due to boom supports. It was likely due to combination of governor gain being to high and possible tail blade stall from using to much throw. My belt did likely get fatigued from slipping before I figured out the cause and that is probably what caused it to snap. Looking forward to trying out the TT. Will the gears be machined or molded?
Old 11-08-2011, 01:11 AM   #16 (permalink)
Look at the TT on this E7/E6.
ID:	265418   Click image for larger version
ID:	265419   Click image for larger version
benben is online now        Reply With Quote Quick reply to this message
Old 11-08-2011, 02:59 AM   #17 (permalink)
TT System -
Matt
THIS is AWESOME to hear Matt great stuff!!!!
Old 11-08-2011, 08:50 AM   #18 (permalink)
Default Update
I got an email from Matt (while he is still in China) and he will be replacing my belt. In addition, the Synergy team has been most gracious and have offered up assistance and parts in order for me to rebuild my E7. I can't think of a better way to help a fellow pilot in their time of need. They really have gone the extra mile in making sure I have support. Kudos to Matt and his Synergy Team!!!
Thank you guys!!!
Old 11-08-2011, 02:50 PM   #19 (permalink)
Yea that was me with the Ungluded boom supports and that is probably why it broke so early! Did not think about that. The new belt is going good though!
Thanks again!
Zack108 is offline        Reply With Quote Quick reply to this message
Old 11-08-2011, 03:33 PM   #20 (permalink)
Wow, amazing customer service. Thanks for your feedback mstlc03
"I got an email from Matt (while he is still in China)...."
Ken Here is offline        Reply With Quote Quick reply to this message
