Old 10-18-2014, 04:24 PM   #1 (permalink)
Default Help with weird clicking noise
I had a crash which bent boom and other head parts etc but didn't bend tail shaft or break tail case or anything like that. After the rebuild I have a weird clicking noise that sounds like it's coming from the tail when spinning the blades by hand. It was pretty quiet so I have been flying it anyway. But after my last flight it is much louder now. Not sure what would be causing it. I've rechecked the belt and it is not twisted.
I'm afraid to fly it like this. What should I check/replace? Do I need to replace all tail bearings? Oddly, it sounds like it's coming from inside the boom
I will try to post a vid of the sound later
SAB Black Thunder Sport
SAB Goblin 570 // 500 Sport
SAB Goblin 420
OXY 3, LYNX Heli Innovations Team Pilot
Teeyo is offline        Reply With Quote Quick reply to this message
Old 10-18-2014, 05:12 PM   #2 (permalink)
Banned User
Post
I would try removing the belt pulley tensioner from the tail case. Then look into the tail boom while shining a light in from the frame side to make sure the belt didnt get twisted at all.
Also you can check if the bolt that goes through the belt tensioner pulley isnt too tight. If it is it can squeeze the tail case and make it rub against the pulley.
kavic5150 is offline        Reply With Quote Quick reply to this message
Old 10-18-2014, 06:12 PM   #3 (permalink)
Thanks, I will try those suggestions
For now, here is the video of what it sounds like
Protos tail clicking (0 min 19 sec)
SAB Goblin 420
Old 10-19-2014, 06:29 AM   #4 (permalink)
Probably idler bearing or tail case bearing. usual suspects.I've added drop of oil to 1 bearing at a time till I noticed a change in tone of clicking to determine which 1 it is.
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is online now        Reply With Quote Quick reply to this message
Old 10-19-2014, 09:10 PM   #5 (permalink)
Bearing going bad. I had the same thing going on not long ago. I ignored it and it finally exploded and locked up on spoolup causing a tip over and 70 bucks worth of repairs. Finally gave me an excuse to put on my metal tail case though!
Mike
Hirobo 450 Embla vbar
Protos 500 stretched vbar
Trex 600 efl Pro vbar
mike d1 is offline        Reply With Quote Quick reply to this message
Old 10-20-2014, 08:34 AM   #6 (permalink)
Mike
Same thing happened to me...
When I hear the clicking I change the bearings...
Chief
RC Chief Hobbies
MSH Protos 500 Flybar, Gaui 200 V2 Flybar,V120D01, V120D02S,MCPx (retired)
Boating Fleet: Toysport Syncron and Triton Monos, 1/10 scale 1967 Miss Bardahl Shovelnose Hydro, Executone semiscale Hydro, OPC Tunnel, Miss Geico Cat
BHChieftain is offline        Reply With Quote Quick reply to this message
Old 10-21-2014, 03:17 PM   #7 (permalink)
I once had the clicking sound and after adjusting the tail and motor mount again, the click was gone.
There is a fine adjustment point where the relation between the main pulley, tail,pulley and pinion has to be correct, and it appeared somehow the belt was trying to climb the pulley and then was "clicking" into place.
I always try to adjust the belt in small steps,moving both the tail and motor mount.
MSH Prôtos CF FBL Stretch
E-flite HABU 32, Parkzone HABU 2
Ikarus F3A
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote Quick reply to this message
