Old 10-12-2014, 03:54 AM   #1 (permalink)
Default 12v from Meanwell RSP-2000-48
The RSP-2000-48 has the capability to be switched on and off and provide 12 volts through an auxiliary 12 pin plug.
Has anyone used the 12 volt power or the on/off switch capabilty?
I have been trying to find a female plug for the 12 pins to use these features but cannot find any references to it anywhere. Has anyone used one, made one?
Are others using other means to get both 24v and 12 volt outputs?
thanks
Stu
awesomeOne is offline        Reply With Quote Quick reply to this message
Old 10-12-2014, 08:46 AM   #2 (permalink)
What do you want to use the 12V for? Per the manual, the 12V output is limited to 0.8A. So it might start to get overloaded just running a fan or two.
If you were trying to do something like run some fans in a case, a few simple options come to mind. If using 4, get 4 identical 12V fans, and wire them in series, to the 48V output. Now each fan gets 12V. If using 2 fans, get 2 identical 24V fans, and wire them in series, giving each one the 24V it wants.
Another option for >1A of current would be to get a 12V voltage regulator that can handle 50V input, and run it off the 48V output. Like using a BEC to get 6V from your 25V packs. Or, get a small 12V supply that runs off 110V or whatever you're using for your input power, and use that, rather than using an output from the supply.
As for remote on/off, look in this thread. It's about the 1000W RSP, but I'd expect that function would likely work the same way on both.
https://www.helifreak.com/showthread.php?t=516573
Old 10-12-2014, 01:27 PM   #3 (permalink)
For 12v, Red is correct. The output is too small to useful more most auxiliary uses. There is case builder in town that uses this supply. For auxiliary 12v power they add in a second low power, DC supply. Although a low power DC-DC converter would likely work as well. If weight and space is not an option, a repurposed laptop supply would work well.
Gregor99 is offline        Reply With Quote Quick reply to this message
Old 10-12-2014, 04:16 PM   #4 (permalink)
Thanks guys. Great options. I had not realised that the amps from the 12v were so small...
And Red you are correct, I was thinking of fans, USB and maybe some LED lights.
