Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > X400 and MX400
X400 and MX400 Ark X400 and HeliMax MX400 Helicopters Information
Old 06-14-2007, 03:14 PM   #1 (permalink)
Default Blade tacking problems?
Any of you have blade tracking problems? I cant seem to get any blades to track on this head. Right now im using the brand new align 3k white carbons and they are perfectly balanced and the quality is near perfect but I cant get them to track on this head neither can I get the align 325 pro woodies to track.
mx400 is offline        Reply With Quote Quick reply to this message
Old 06-15-2007, 08:25 AM   #2 (permalink)
buy the align links for the head , the links from the grips to the mixing arms are threaded unlike the mx .
Thorimmortal is offline        Reply With Quote Quick reply to this message
Old 06-17-2007, 04:19 PM   #3 (permalink)
Default Re: Blade tacking problems?
I am having the same issues...can only really track the stock 285's. I have the extended boom, and the 325 Align woods and the helimax 325 CF are so hard to track, the CF is WAY out of track, makes the tail shake so hard. Any ideas?
flag8r77 is offline        Reply With Quote Quick reply to this message
Old 06-18-2007, 02:12 AM   #4 (permalink)
I have align links and adjusting them does no good Ive tried rotortechs just got to try radix last night and align 3k's align pro woodies 325 nothing will track and they all track great on the trex head. I dont get it im going to start swapping out the mx450 head parts for align and see if I can narrow down the problem.
Old 06-18-2007, 06:37 AM   #5 (permalink)
if you don't already have one,you need to install the center hub with ball bearings.
Wb
The wind is my teacher.
windbender is offline        Reply With Quote Quick reply to this message
Old 06-18-2007, 11:37 AM   #6 (permalink)
Its got ball bearings.....
Old 06-18-2007, 12:00 PM   #7 (permalink)
Are you using align grips?
helisforfun is offline        Reply With Quote Quick reply to this message
Old 06-18-2007, 07:48 PM   #8 (permalink)
Default tracking
No, Im' using stock helimax blade grips, why?
Old 06-18-2007, 08:01 PM   #9 (permalink)
I had the same problem using the x400 grips and different spacers most trouble was with using the used plastic inserts from old x400 grips upon closer inspection I noticed they were not flat and actualy changed the angle (pitch) each time I un folded the blades after transport. I changed to align grips easy mod no more tracking problems. I'm using the plastic grips they have broken away in a crash saving more expensive parts.
Just sharing my mistakes
Old 06-18-2007, 08:56 PM   #10 (permalink)
Default grips
[Just to clarify...your using the Align plastic grips? Im so frustrated with tracking at this point! Do the grips come with all the bearings, feathering shaft, etc? Any and all info you can provide would be great, thanks so much.
quote="helisforfun"]I had the same problem using the x400 grips and different spacers most trouble was with using the used plastic inserts from old x400 grips upon closer inspection I noticed they were not flat and actualy changed the angle (pitch) each time I un folded the blades after transport. I changed to align grips easy mod no more tracking problems. I'm using the plastic grips they have broken away in a crash saving more expensive parts.
Just sharing my mistakes[/quote]
Old 06-18-2007, 10:47 PM   #11 (permalink)
Good info here (http://www.x400tuning.com/) look in the forums you will find info on the align grip mod.
its easy just buy the grips and feathering shaft you will use the same orings and bearings and the feathering shaft should come with allen screws
advantage hobby (http://www.advantagehobby.com/ )
Old 06-19-2007, 04:10 PM   #12 (permalink)
I will stick on my trex blade grips and see what happens I already use trex feathering shaft.
Old 06-20-2007, 02:23 PM   #13 (permalink)
Default Maybe this
This may be caused by slop in the upper mixing arms. I fought blade tracking and generally sloppy control until I discovered this mod.
jrohland
jrohland is offline        Reply With Quote Quick reply to this message
Old 06-20-2007, 04:54 PM   #14 (permalink)
It does have quite a bit of slop in the upper mixing arms.
Old 09-23-2007, 06:36 AM   #15 (permalink)
[QUOTE][
Maybe this
/QUOTE]
that link is dead, what is that mod? my mx450 is making me suicidal. almost $1000 and she won't even hover yet.
AMA# 906249
i'm now down to one heli (align sev2) but have an arsenal of 120+ mph jets. hmm...i think i see a pattern here lol.
istandalone is offline        Reply With Quote Quick reply to this message
Old 10-15-2007, 04:11 PM   #16 (permalink)
I would like a little more info on this as well. I own a Trex 450SE v2 but my neighbor has the MX450 and I can not get tracking closer than an inch from blade tip to tip. It is terrible. I can pull the blade grips in and out about 1 centimeter and by looking at the manual everything is set-up correctly.
Kyosho Caliber EP 120..... Walkera 4G3.....
Blade MCX..... Blade CX2..... Blade CP Pro.....
Trex 450SE V2..... Trex 600E CF
thaiboxer is offline        Reply With Quote Quick reply to this message
