Old 01-24-2012, 10:49 AM   #1 (permalink)
Default Ryan's Trex 800 AP
I guess I'm going to start a build thread. Trying to keep all my progress and ideas in one spot.
I'm building an AP heli around 700E mechanics stretched to 800, the basic 800 setup I guess. Except I'm making some of my own parts for the fun of it.
These are my battery mounts:
These are the beginning of my tail boom supports, with room to mount my autopilot equipment.
I will update as I go. I'm working on landing gear now.
FlightCam
http://ryanbarnes.smugmug.com/
Cirkus is offline        Reply With Quote Quick reply to this message
Old 01-24-2012, 10:59 AM   #2 (permalink)
Nice boom/battery support setup...
I have the completely opposite trouble ..my batteries have to be as far forward as possible
JR9303 / JR9503 / Futaba10CHP
nightflyr is online now        Reply With Quote Quick reply to this message
Old 01-24-2012, 11:17 AM   #3 (permalink)
I'm trying to balance everything as I go, and have enough adjustment with equipment placement to be within reason CG-wise when everything is bolted on. My most difficult decision right now is what camera I will be running. I'm leaning towards a Sony NEX-7 when I can get ahold of one, but I think I'll eventually end up with a couple different payloads based on the job requirement.
FlightCam
Old 01-24-2012, 11:45 AM   #4 (permalink)
Figure on the max/min payloads.. simulate with weights and make it adjustable between the two
Old 01-24-2012, 11:50 AM   #5 (permalink)
That's the process
FlightCam
Old 01-24-2012, 11:14 PM   #6 (permalink)
I'm replacing my Raptor 90 Hughes 500 gear with something a bit more sturdy. It needs a set of gear more proportional to the size of the heli. Here's the front gear legs. The skid holes are sized for 700-size boom tubes, which will be wrapped in pipe insulation or a bright colored "pool noodle" float. I should be cutting the rear legs tomorrow, I ran out of material for now.
The comparison with the previous gear.
FlightCam
Old 01-25-2012, 12:02 AM   #7 (permalink)
I got my 5.8 Tx, the circular polarized antennas, and the camera I will use on the viewfinder of the DSLR for framing the shot.
I also got another Skookum power distribution bus. I use them on all my big helis.
FlightCam
Old 01-25-2012, 02:48 AM   #8 (permalink)
Nice set of landing gear
One item you might consider..
The slots cut to accept the mounting flange you made will be the weak point..
I can see where the leg would fracture on a hard landing.
Might I suggest a different tact..
A piece of "U" channel installed inverted between the legs and screwed in place, this will also allow you to use the stock mounting positions.
Just a thought...
Old 01-25-2012, 05:58 AM   #9 (permalink)
Do you have the equipment to cut the parts yourself, or are you sending some CAD files to a service that cuts the parts out for you? I'm mostly interested because I've often wished I knew of such a service.
MattFL is offline        Reply With Quote Quick reply to this message
Old 01-25-2012, 10:03 AM   #10 (permalink)
Just a thought...
Thanks for the suggestion, you're right that point is the weakest place. However I did it that way to hopefully prevent the frame from shattering instead. I can spit out landing gear at will, but replacing my frames will require much more tear down. At any rate, if I have an auto that ends up breaking parts I think I will have bigger problems than just that to worry about.
FlightCam
Old 01-25-2012, 10:18 AM   #11 (permalink)
I recently bought a CNC router because I had a need for parts no one makes. I was proficient with the CAD software already so having a machine that could spit out those ideas was the next step.
FlightCam
Old 01-26-2012, 12:38 AM   #12 (permalink)
Landing gear finished
Sorry for bad pics. I'll get outdoor pics tomorrow.
FlightCam
Old 01-26-2012, 12:46 AM   #13 (permalink)
Just out of curiosity, what kind of router and how much does something like that cost?
Av8Chuck is offline        Reply With Quote Quick reply to this message
Old 01-26-2012, 01:00 AM   #14 (permalink)
Www.probotix.com. I got the V90, but I want to step up to a Comet when funds allow.
The base machine starts at about $600, but with electronics, tooling, clamps, and all the little stuff you end up buying with it it's about $2,000.
FlightCam
Old 01-26-2012, 07:30 AM   #15 (permalink)
That is beyond sweet, I didn't know those things were so affordable these days (relatively speaking). Of course I have to show my wife, that makes me look like a saint as far as hobby expense goes! I took some AutoDesk AutoCAD classes back in school (in the 90's) but have no practical experience since then, it must be great to be able to make your own parts. If you had the desire, I'm sure you could make some good cash making custom parts. There doesn't seem to be any other well known alternative right now so you could charge a premium.
Last question; on all these AP rigs I see the foam around the landing skids. What's the main purpose of that? Is it to prevent ground resonance when the heli is spinning up?
Old 01-26-2012, 08:10 AM   #16 (permalink)
I think that is part of the reason, but for me it mostly helps in visual orientation while flying.
FlightCam
Old 01-26-2012, 08:24 AM   #17 (permalink)
Nice work
Old 01-26-2012, 12:45 PM   #18 (permalink)
Looks VERY nice! Well done.
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote Quick reply to this message
Old 01-26-2012, 01:13 PM   #19 (permalink)
Landing gear looks good bro, you gonna make a pair for me too,,,i like the machine too, it is easy to operate?
Teco
teco is offline        Reply With Quote Quick reply to this message
Old 01-26-2012, 01:14 PM   #20 (permalink)
Thanks Chris, that means a lot coming from you, I know your work.
FlightCam
