Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 04-05-2010, 09:35 PM   #41 (permalink)
Default Re: Project Blade SR "Pro" - Brushless Tail
M52,
Does your battery drain quickier with having the bl tail motor and another esc?
Also, can you use that gyro on the stock tail motor?
DX7 - T-REX 450 Sport Super Combo, Spartan Quark, JR3500G, Eflite SR, MSR & MCX
jmancuso is offline        Reply With Quote Quick reply to this message
Old 04-05-2010, 09:44 PM   #42 (permalink)
Originally Posted by jmancuso View Post
M52,
Hi,
Yes the detrum gyro would be a upgrade for the stock tail motor and ESC.
Running in idle up the entire flight I am seeing flight times around 8 minutes with mild 3d (loops, rolls, inverted) and FFF.
M52 POWER! is offline        Reply With Quote Quick reply to this message
Old 04-06-2010, 05:33 PM   #43 (permalink)
Well I am trying the BL motor route. Installed the parts and had to get myself a new grip so I found the CNC versions, came with links, nuts and bolts for the blades and all the bearings required, nice upgrade I think.
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote Quick reply to this message
Old 04-06-2010, 06:17 PM   #44 (permalink)
Looks good - what motor is that? Also, can you show off the wiring a bit better? I think that's what most of us have a question about. Maybe a schema/larger picture?
Have you flown it yet?
jaydekay is offline        Reply With Quote Quick reply to this message
Old 04-06-2010, 06:31 PM   #45 (permalink)
Looks very good starcruiser. I can't say enough how bad the stock eflite gyro is though, the $17 detrum is a great gyro and upgrade.
Old 04-06-2010, 07:45 PM   #46 (permalink)
M52, i'm sure you've said, but can you post link again to where to get the detrum servo and model? Thanks In Advance
Blade SR - Stretch Carbon Tail Boom
EXI 450 Carbon SE
Futaba T7C 2.4 FASST
Southern Heart Soaps Lotions & Potions
hueman09 is offline        Reply With Quote Quick reply to this message
Old 04-06-2010, 07:52 PM   #47 (permalink)
All the parts he's mentioned are in the beginning of the thread w/ links.
Old 04-06-2010, 07:54 PM   #48 (permalink)
Thanks Jay, I did a search on the thread but must not have done the search proper
EXI 450 Carbon SE
Old 04-06-2010, 07:56 PM   #49 (permalink)
No worries
Old 04-06-2010, 09:28 PM   #50 (permalink)
Yes, I flew it earlier, definitely way less wag, working on the gyro, trying a piezo unit might try the E-Flite one too just to see how it reacts with a better motor.
The only draw back is the tail motor runs all the time even with the TH on. I am playing with the Mixes and will see if I can come up with a happy median.
Carl
Old 04-06-2010, 09:31 PM   #51 (permalink)
That sucks! Any way around that?... Didn't think about that and just placed my order - lol...
Old 04-06-2010, 09:37 PM   #52 (permalink)
Old 04-06-2010, 09:44 PM   #53 (permalink)
these are the parts. The tail motor is what the LHS had in stock, it is a BL 3850KV motor 3s
Carl
Old 04-06-2010, 09:54 PM   #54 (permalink)
Carl - Larger pictures pleeeease! Just kidding - thanks
Old 04-07-2010, 05:33 AM   #55 (permalink)
Default Stopping the tail in Hold/No throttle
Love the brushless tail conversions
How hot are the motors running? On fixed wing the 4000KV motors on 3 cells would be too wild and would be burning out, I guess the tail motor isn't running near full speed all the time
How many flights have your got out of them so far?
Here's my idea for stopping the tail motor from spinning when the rotors aren't turning
http://www.hobbycity.com/hobbycity/s...idProduct=8833
Just a theory but should work
"Y" this to the receiver's throttle channel and use it to power the tail motor esc
If it works as I expect, the tail esc would get it's power once the main esc goes above 50%, should be fine as it can handle 10A, as long as it's quick enough to respond
Shame the 50% isn't adjustable, I guess this would be OK, unless you went below 50% on decent, this isn't stick position, it's the level going to the main esc
I'll try it when I do a brushless conversion, but that won't be for a little while
For those trying to stop the tail with mixes, what happens if you set the remote gyro gain to 0%? (would need to modify end points on the gyro channel) If this disabled the tail, then with some clever mixing you may be able to use this as an option
toys2cars2toys is offline        Reply With Quote Quick reply to this message
Old 04-07-2010, 06:25 AM   #56 (permalink)
Guys in order to stop the tail rotor from running in throttle hold I use the following mix in my DX7:
mix2
thro-->rudd
rate 0%
-125%
sw:hold
offset: 0
Works great
Also the arming sequence is unique too.
1. Throttle hold off, Normal mix on, throttle stick down all the way (duh ).
2. Plug lipo into heli, let it initialize the main esc and gyro (gyro light will go from blinking to constant on).
3. Flick throttle hold to ON on the TX, the tail ESC now initializes (the custom mix above sends full left signal to the rudder channel. The tail ESC sees this as "low" and initializes).
As far as how hot the motors are getting; The main motor is barely warm and the tail motor is warm, but not very much. After a flight I could comfortably hold my finger on it for 10+ seconds. I'm using the stock blue heatsink on it too with some thermal paste.
Oh and newbies take note in starcruiser's first giant photo, the servo wire lead from his tail esc to RX has the positive pin pulled. This is very important so you don't get BEC's conflicting together.
Old 04-07-2010, 07:54 AM   #57 (permalink)
BTW, those are the last of the 5MP photos I will scale them down again.
And yes the positive pin of the tail ESC was pulled to avoid power supply conflicts. I was thinking of checking the gyro and see if the positive power pin is straight thru, thus I could pull the gyro instead and use the tail ESC to power the tail components. Hummm.
Motor is warm, I installed the heat sink also (see photo above) to avoid any over heating, tail is running about 50% or less so I do not think it will have issues.
I will try that mix M52 and see if that works, I am using a DX6i so I hope that works the same.
Carl
Old 04-07-2010, 12:08 PM   #58 (permalink)
Is this mod compatible with the stock TX and ESC?
__________________________________________________ __
Blade MSR, SR Spektrum Dx5e (soon to be upgraded to Dx6i)
epicjaps is offline        Reply With Quote Quick reply to this message
Old 04-07-2010, 01:24 PM   #59 (permalink)
You could use the stock ESC and Yes the Rx is fine, I am not sure about the stock Tx though, I use a DX6i. You need to add at a minimum another ESC for the BL tail motor and change the wiring a bit.
I would recommend another Tx since you need more tweak-ability than what the stock one provides IMO
Carl
Old 04-07-2010, 01:53 PM   #60 (permalink)
mix2
thro-->rudd
rate 0%
-125%
sw:hold
offset: 0
Works great
Well I had a few at lunch to try this and it is a bit different on the DX6i, there is not option for the TH "Hold" just the other switches, I chose the AILE D/R switch
The MIX settings for a DX6i are;
THRO > RUDD ACT
RATE L +125% R 0%
SW AIL D/R TRIM INH
This seems to allow power up without having to pull the rudder to the left and a way to power down the tail for safety.
Still need to wait until the power up cycle for the main ESC and Gyro (in HH mode) and then flip- the control switch (AIL D/R) to allow the tail ESC to arm. When ready to fly, take it out of TH and flip the AIL switch all is good. I wish I had the hold option for a single switch activate, but it is what it is for now.
Now to mess with the gyro settings some more
Carl
