Old 12-24-2011, 01:27 AM   #41 (permalink)
was no one else impressed with the speed of that 700e?
honor guide me
Tronix is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 06:54 AM   #42 (permalink)
Anyone besides me worried about boom strikes? Keep lowering the head, it's not if, it's when...
On both my 700N and E's, there were very small dings in the boom with the FBL main shaft and V2 head where the blades barely clipped the back on the boom on "less than smooth landings". (both with 690mm blades)
The 7HV head is lower. I saw two boom strikes at the Orlando Heli Blowout with these models. Both were catastrophic.
This Align DFC design appears to be lower than both.... May not be an issue, But, has to be a concern, right?
[COLOR=Navy] #FutabaUSA , #XLP, #SpinBlades
MarkFlysHelis is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 12:31 PM   #43 (permalink)
Do you know whos models this happened to?
BakedMopar is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 01:13 PM   #44 (permalink)
1 was Kettlehut, don't know the other.
Old 12-24-2011, 02:42 PM   #45 (permalink)
hopp they make this head for the 450 heli
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 06:27 PM   #46 (permalink)
Thanks.
Old 12-24-2011, 07:02 PM   #47 (permalink)
Default 3rd Mainshaft Bearing
Originally Posted by znbang View Post
DFC is Direct Flight Control.
Maybe no one else noticed but if you look at the mainshaft lower hole, the bottom of the shaft has been extended to reach a 3rd main bearing...
Just another crappy day in Paradise.... Aloha!
CNCjunkie is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 07:39 PM   #48 (permalink)
That looks to be correct. The length below the hole is greater than the current mainshaft. Finally.
terrabit is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 09:10 PM   #49 (permalink)
If you've seen Kettlehut fly, you'd realize he could boom strike any heli. He maxes out cyclic and pitch quite often in his routine.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 09:16 PM   #50 (permalink)
Yea, I know him, seen him fly MANY times. Great guy, great pilot.
To say he or anyone else that fly's hard smack could boom strike any heli is a stretch.
Point is, You keep moving the blades closer to the boom, Strikes are going to occur more often.
Old 12-24-2011, 10:08 PM   #51 (permalink)
Part of getting a boom strike is setup. I seem to recall he runs extreme pitch/cyclic and likes to peg the sticks. My point is he's not a good example for this discussion.
Old 12-24-2011, 10:22 PM   #52 (permalink)
I knew it would only b a matter of time.
NO FLYBARS
504Rone is offline        Reply With Quote Quick reply to this message
Old 12-25-2011, 05:23 AM   #53 (permalink)
the only difference with the Compass head is that Compass uses delrin tubes as for Align everything is alu.
Compass used the delrin rods in order to put less stress on the swashplate and alse to let them compensate the phasing, I wonder what these Align alu rods will be doing to your swashplate after a lot of hard flights. Time will tell ......
Grtz,
Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
Warp 360 / 6HVU / CY Stingray / Invertix 400 / SH Little Spyder
Dflyer is offline        Reply With Quote Quick reply to this message
Old 12-25-2011, 11:17 AM   #54 (permalink)
Grtz,
Dirk
SAB has aluminum rods also
brian94066 is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 07:01 AM   #55 (permalink)
Well i think this is great, align have really stepped up there game recently for the better,
I do think they will offer this as an upgrade and not as standard e.g a combo
More money that way for them and for the non hard 3d guys they could be more than happy with the way the head ia now? I would be, beautifully made rotor head.
lloydcole is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 10:10 AM   #56 (permalink)
I like the design. Just wondering what part is sacrifical in a crash now that the blade grip links are so robust.
Servo Gears?
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 01:43 PM   #57 (permalink)
Servo Gears?
It'll probably be one or a combination of servo gears, bladegrip arms and swashplate. Best case would be a ball-link or so. I wasted a set of servo gears and grip arms with the v2 setup in my last crash.
Old 12-26-2011, 02:28 PM   #58 (permalink)
BD Forum Support
Actually what's the problem with the current head?
popokatepetl is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 02:36 PM   #59 (permalink)
Nothing, I actually use the V1 grips with KDE head and its better than I am.
I think the Direct Flight Control head, shorter shaft and control rods/arms will speed up the roll behaviour, a little less kinetic energy. It seems to move the mass closer to the center and without the washout and a more rigid control arm a pro may find better more accurate control.
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 07:38 PM   #60 (permalink)
The Compass head design does have some great innovations to it for simplicity, so I can see the attaction to it from a manufacturing standpoint.
One question I have is the height of the blades to the tail boom with this new head. If you study the Compass 7HV design, it appears to have a very short-shaft and lowered head design, but the frame is designed such that it sits considerably higher than the ALIGN frame and the boom sits below the level of the main gear. In this regard, good mechanics allows for a short-main shaft (where all the bending loads are concentrated), with still adequate clearance for the rotor head above the tail mechanics.
Can someone measure the distance from the bottom of the main blades to the tail control rod on the Compass 7HV (essentially, the height for blade-flex allowance)? I bet it will be surprising that this isn't much lower than the current ALIGN design, as the ALIGN tail boom sits much higher in the frames and thus, requires a higher blade-location for proper clearance.
At 2300 rpm, the blades are significantly more loaded in centrifugal forces to prevent blade flex. At 1950 rpm on a Nitro, I'm hesitant to believe this won't be busting tail booms - I'm curious to see this in action and see if blade-flex isn't as much of an issue as it was in the past. Maybe ALIGN will recommend a minimum headspeed or pitch range to prevent issue (probably smart not to run anything longer than 690s as well)?
-- KDE Direct, Inc. --
KDE Direct is offline        Reply With Quote Quick reply to this message
