Old 05-01-2014, 03:39 PM   #1 (permalink)
Default icharger 306B wire heating
hi
I recently got a 306B. When I run it at full 20amp and 12v, the input wires get extremely hot. At one point it melted the plastic coating and caused a short. Luckily the PS detected it and shut off. Anyone know why it's happening? its running 12 awg wire on the input side.
demon31 is offline        Reply With Quote Quick reply to this message
Old 05-01-2014, 03:58 PM   #2 (permalink)
Default Re: icharger 306B wire heating
20A output, with what cell count? Do you know how many amps it was pulling from the supply?
What are the connectors on the supply? Is it a commercial supply, or is it possible you have a bad solder joint on something you made, causing high resistance and heat?
A higher voltage supply will require less amps, and will keep the wires cooler.
Sent using Tapatalk.
Old 05-01-2014, 04:22 PM   #3 (permalink)
I'm charging 3x 6 cell batteries. It's a single dell 1000w supply. I actually just used the alligator clips to clip it to the output pins of the power supply. It's not pretty but it works (or maybe not)
Old 05-01-2014, 04:26 PM   #4 (permalink)
Use EC5s on both the power supply and cable end and the cable to charger end... and use jumper cable wire since good quality (even fat 8AWG wire) jumper cables are cheap. I run 8 feet (24V) and it barely gets warm even at 60A input. 24V would help too with your current setup... twice the voltage = half the amps (and heat)
I kept the clamps on one end of my jumper cable since I power with deep cycles instead of PSU.. but that doesn't make any difference to the wire of course.
Like this (on your PSU)
Old 05-01-2014, 04:30 PM   #5 (permalink)
If in understanding correctly, are the alligator clips next to where it melted? I would expect they would add resistance and heat.
I would solder to the supply, preferably 10AWG or thicker, with at least 4mm bullets. EC5 would also be very good.
A second supply, for 24V, will keep things cooler, and also allow more power from the charger.
Old 05-12-2014, 08:59 PM   #6 (permalink)
I've had a similar issue. I re-soldered my connections on the power supply I was using and changed the 3mm connectors to 5mm on the input wires. that helped but the wires still get a little warm.
I have another power supply I would like to wire up for 24vdc but I have a turnigy mega 400 v2 and it states only up to 18vdc input.
Drivelayer is offline        Reply With Quote Quick reply to this message
