05-05-2015, 05:57 PM | #1 (permalink) |
Bought a used 500GF, thoughts on needed upgrades?
Hi. I am new to CP helicopters. Having wanted to make the transition for years, I finally made the plunge and got a used t-rex 500 GF (flown 20 times), along with a 450 and a 450 sport for $600 with a Dx6i and lots of parts. I initially wanted a new 500E, but those are impossible to find in my corner of the world at the time.
How does it fly compared to a modern T-rex? What are some recommended upgrades I should make? I want to convert it to a FBL eventually, since there's constant winds on my island. A bailout function like the ikon would probably be wise as well. Since it's such an old model, I've had problems finding much info on it. How is the compatibility with the newer models parts-wise? I realize I should have done this research before buying it, but I am recovering from surgery and summer came early this year, so I needed something RTF to keep me from losing my mind stuck at the house. Any help will be much appreciated! |
05-07-2015, 04:23 AM | #2 (permalink) |
The 500GF flyes very well, its compatible with all 500 ESP/CF/ parts. Probably the most important upgrade is the motor, the 500L is OK with 12T pinion, but if you want governor and add the needed 13T or 14T then the motor lacks power. Add a reliable external BEC, and a better ESC. No other upgrades are really esential.
The ds520 tail servo is good enough, at some point you may want to change it with some lightning fast tail servo, but I wouldn't hurry for that. Some parts from the 500E pro do fit either, as the tail grips, those make great upgrade if you damage the original. However the metal tail grips ask for a chinese weights that yo can make using larger bolts for the tail blades. |
05-07-2015, 12:10 PM | #3 (permalink) |
I bought an FG version too and I did bunch of upgrades.
I convert to FBL using a TREX 500 EFL head. You need:Align 500EFL PRO Metal Main Rotor Housing H50148 ALIGN TREX 500L Metal Main Rotor Holder H50150 Align Trex 500EFL PRO Metal Main Rotor Holder Arm H50152 ALIGN TREX 500L Metal Control Arm H50180 ALIGN T-Rex 500FL Linkage rod(A) set H50130 New You use same spindle shaft, main shaft and grip ball bearings. I use the Beastx (and RX) with with a co-pilot 2.(NB: the co-pilot can be turned on only when the helicopter is air born when used with a FBL controller) Added a CC BEC PRO,a CC Phoenix Ice 75 and Scorpion 3226-1400 (3026-1400) motor. All those except the head parts where found here on HF used.
SYMA S-107/BLADE (2)450 3D FBL/ALIGN(3)T-REX 500 (2)T-REX 550 T-REX 700L V2/DX8 SCALE MD500(450) UH-60/AS350/BO105(500) A109(600) |
05-07-2015, 03:34 PM | #4 (permalink) |
If you are just starting out, it will be plenty. Not the most modern helicopter, but you can still find parts for it and it flies plenty well for training and sport flying. I have a 500, upgraded a few things, but flies great and does everything I ask.
Team Synergy |
05-07-2015, 06:35 PM | #5 (permalink) |
Thanks a lot for your help! The part numbers were very helpful! I was getting worried that I screwed the pooch by buying a first gen T-rex, since I couldn't find much info on it from the last 5 years. Hopefully getting the package tomorrow, can't wait to geek around with my new gear!
06-18-2015, 05:12 PM | #6 (permalink) | |
I bought a fusuno ex canopy which has room for a bigger battery, what would be the largest battery it would support with stock parts? Currently in the hospital and don't know what ESC is in it, but I imagine it is standard from 08-09. |
06-19-2015, 03:21 AM | #7 (permalink) | |
Chinese weights are weights added to the tail grips that counter the racketing effect that force the grips to remain centered. The faster the rotor spin and the heavier the grips, the stronger the force, so if your tail servo is not strong enough it may be overpowered by that force. Adding some weights on both sides of the grip like larger bolts, shims, etc counters that forces. Check google for a better explanation. |
