Old 12-10-2012, 03:19 PM   #41 (permalink)
Originally Posted by jhheli View Post
Gov store saves the rpm at the throttle percentage, so if you put a dead, weak or charged battery the head speed is the same at that throttle percentage, On my Goblin 700 I don't use gov store, just mode 1 and then mode 4, on the 770 it will be the same, all other helis I have set up none rune gov store.
Since I'm using the same pack each time, gov store isn't really necessary? I mainly use it with YGE in order to have auto bailout.
Sent from my DROID RAZR using Tapatalk 2
aviator493 is offline        Reply With Quote Quick reply to this message
Old 12-10-2012, 05:42 PM   #42 (permalink)
Makes since.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 12-26-2012, 01:14 AM   #43 (permalink)
why do you set Mode 1, then Mode 4?
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 12-26-2012, 01:54 AM   #44 (permalink)
So from what I can see, a progdisk isnt necessary if I'm not using the BEC or any complicated gov function right?
rebeltrousers is offline        Reply With Quote Quick reply to this message
Old 12-26-2012, 11:18 AM   #45 (permalink)
Rossk Mode 1 learns the throttle path and resets the ESC and BEC to defaults.
Yes thats correct.
Magneto is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 02:46 PM   #46 (permalink)
what is the default BEC output voltage of the Kosmik 160HV ? i have the Outage Servos 9180 and 9188, i know the more voltage you have the faster the servo will be running, is the default voltage of the BEC enoght for my outage servos ?
Just a confirmation, so i need only to configure Mode 1 and Mode 4, i have a Goblin 770 with HC3-SX Gyro, and a futaba 8FG Super.
I guess the Throttle have to be REVESED as on all other BEC too..
One last question, for mode 4 in the manual it say to use a 2 postision switch, low position set to 0% and position 2 to 100%, i tought i only have to put the throttle stick to 0, and then push it to 100% after 4 bips, i am a little confused.
thanks !
mmarmouz is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 02:54 PM   #47 (permalink)
thanks !
Yes throttle is always reversed on anything Futaba.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 01-12-2013, 03:34 PM   #48 (permalink)
My kosmik 160HV is now at mode 4, so autorotation bailout will be enable by default ?
i know manual talk about 25% on the transmitter, does it mean my normal mode have to be at 25-25-25-25-25 ? i i should use the throttle hold before take off ? and switch to normal, then turn off the throttle hold ? after takeoff switch to idle1 ?
here is what i have now setup on my transmitter
Nomal 0-55-55-55-55 (~1300rpm)
IdleUp1 75-75-75-75-75 (1688rpm)
IdleUp2 80-80-80-80-80 (1830rpm)
IdleUp3 85-85-85-85-85 (1945rpm)
Old 04-10-2013, 02:15 PM   #49 (permalink)
Hi
No you have picked it up a bit wrong and confused yourself.
When you go to the Throttle Hold menu in your transmitter it has a value, normally 0. It is in this menu that you put the 25% value.
Leave your values for throttle curves as you had them, ensure Normal starts at zero and goes to a straight line thereafter:
0,55,55,55,55 is ok.
What radio do you have? I only ask as the % for JR/Spektrum is 25% but Futaba is 30%
Kind regards
Stuart
Logo Xxtreme 700, Kosmik/Scorpion, HC3-SX, 451/251, Edge
Logo 600sx, Kontronik, vBar, 451/251, Edge
Logo 500se, Kontronik/Scorpion, HC3-SX, 451/251, Edge
Avant Ultimate Ys91SRS/Hatori, vBar, 451/251, Edge
Stuarty is offline        Reply With Quote Quick reply to this message
Old 04-10-2013, 09:48 PM   #50 (permalink)
Default Kosmik setup video
Or you can keep throttle hold as throttle hold, and instead make one of the flight modes your auto rotation mode, 25% flat curve.
So you will flick into this mode, do your auto, hold when landed.
To bail out, flick back to one of your other modes.
I am super quick to hit TH when something goes wrong(reflex), so I want to maintain that.
Old 04-11-2013, 08:29 AM   #51 (permalink)
I couldn't agree more with that statement. I even though about mixing another switch with hold but your idea sounds just as good, and a lot simpler.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
