Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Fuselage Forum
Fuselage Forum Fuselage Discussion
Old 01-03-2010, 11:08 PM   #621 (permalink)
Cool torque tube installed
I installed the V3 torque tube on my SE. I did have to install the elevator servo on the outside of the frame. That did cause the servo to hit the fuselage. I removed two of the plywood pieces out of the stand off blocks and that lowered it enough for the servo to clear the fuselage.
I was woried about the flybar now having even less clearance but what the heck nothing ventured nothing gained... I took it out today and i wrang her out, high speed turns, vertical stall turns, etc. no problems at all. I figure if the fly bar was going to hit the fuselage it would have.
All in all I would say it was a good upgrade, I would have been sick if I had a belt break in mid flight. I did not see any difference in flight time though, Oh well this upgrade was for reliability only
Pics to come
slcrcflyer is offline        Reply With Quote Quick reply to this message
Old 01-03-2010, 11:48 PM   #622 (permalink)
Default Torque Tube
Here are some pictures. You can see the elevator servo is shoe horned in the fuselage, despite the removal of two sections of the ply stand off blocks.
ID:	132187   Click image for larger version
ID:	132190   Click image for larger version
ID:	132191   Click image for larger version
Old 01-15-2010, 07:12 AM   #623 (permalink)
Default Tail Rotor
Do you have to take the tail rotor apart everytime you take the heli out of the fuse?
I am building one now and have to take the tail rotor apart to get it in and out. It is a align fuse i am also having a problem getting the heli to set in there with the 9650 servo on the boom? i can't get it in there without it touching the side.
I am tweeking it now and trying to get it worked out. Thanks Jay
cabojay is offline        Reply With Quote Quick reply to this message
Old 01-18-2010, 11:16 PM   #624 (permalink)
you have to take it apart every time on all the scale fuselages
you need to search this thread there you will find that you have to build a mount for the servo to hang vertical on the boom
Old 02-07-2010, 08:19 PM   #625 (permalink)
First off, awesome forum!!! I'm just staring my md500 build using a 450 se v2 clone from kds, and a fuse from heliartist. Finally finished the paint after a TON of sanding and prep, but I think it turned out pretty good for my first paint job. Kinda pricey though, for the paint as I used automotive paint, but I think the effect was worth it here are some pics of the paint process for your veiwing pleasure!
timms is offline        Reply With Quote Quick reply to this message
Old 02-07-2010, 09:30 PM   #626 (permalink)
ok, try this again
ID:	138285   Click image for larger version
ID:	138936   Click image for larger version
ID:	138937   Click image for larger version
ID:	138938   Click image for larger version
Old 02-09-2010, 06:50 AM   #627 (permalink)
Originally Posted by timms View Post
ok, try this again
NICE BODY PAINT
I just almost finish a MD-500e and on maiden flight the tail is going down but real hard i don't know if the heli needs some weight on front but wend i pic up the heli to balance it through the fly bar it seems level.Any recommendation how to balance the heli.
heli bob is offline        Reply With Quote Quick reply to this message
Old 02-12-2010, 06:28 PM   #628 (permalink)
Hey guys on the build time of my 500e from aling some mod to the front part.
ID:	139086Click image for larger version
ID:	139087Click image for larger version
ID:	139088Click image for larger version
ID:	139089Click image for larger version
ID:	139090Click image for larger version
ID:	139091Click image for larger version
ID:	139092Click image for larger version
Old 02-12-2010, 09:16 PM   #629 (permalink)
Wow, I though my crack in the front windshield looked bad. Can you even get a new front fuselage?
T28c is offline        Reply With Quote Quick reply to this message
Old 02-13-2010, 05:43 AM   #630 (permalink)
I did check all the web i coundn,t find it so i took it to a freind that works with lexan and try to make it but it was to hard to heat it up in to a point to shape it and not to over heated. so put FG on it is a very thin not the clogth it come in a can very lite to work and easy.
Old 02-13-2010, 10:17 AM   #631 (permalink)
I guess i better figure out how to make a mold and but it in my vacuum former. If not, it looks pretty cool what you did.
Old 02-14-2010, 12:24 PM   #632 (permalink)
I saw a guy in youtube that works with clear acrilic or flexi glass but he has framed for it and oven set in temp for it it looks easy but is not.to make the windows for the heli.
Old 02-14-2010, 12:44 PM   #633 (permalink)
In my Align fuse kit they provide screws to fasten the wood blocks to the trex frame. These screws are pretty soft and phillips style. Is anyone using a hex head and where did you find the size. I've looked everyplace for replacement and can't find them anyplace. Nice hard hex head cap screw..self tapping. The ones that are for the stock Trex450 skids are too short also. Drats
browndog is offline        Reply With Quote Quick reply to this message
Old 02-16-2010, 07:34 PM   #634 (permalink)
some of the guys order from this web page
http://home.pronto.com/mpm/shop/scre...rews+hex&site=
Old 02-17-2010, 11:07 AM   #635 (permalink)
Still enjoying mine; 500e since late 2008 and 500D early 2009.
ID:	140060   Click image for larger version
ID:	140061   Click image for larger version
sidneyw is offline        Reply With Quote Quick reply to this message
Old 02-18-2010, 08:13 PM   #636 (permalink)
Man, I love the look of those. Can't wait to finish mine. She's set up but only as stock. I wanna get it into my new fuse but know better.
Old 02-18-2010, 10:45 PM   #637 (permalink)
ok, so i'm on the home strech of my build and I've come to a bottle neck, almost literely. I've got everything done as far as moving and/or repositioning servo's, epoxying the risers, ect... My problem now is how do you install the mechanics and still maintain proper belt tension??? Do you dissassemble the tail assembly before placing inside fuse, or do you loosen the tube from the frame and re tighten once mechanichs are inside? disassembly of the tail rotor is easy, re-assembly is a different story with an already tense belt, especially the tensioner! Is there a way to do this without going nuts??
Old 02-18-2010, 10:46 PM   #638 (permalink)
hopefully without installing torque tube?
Old 02-19-2010, 05:50 AM   #639 (permalink)
Can you not just remove the tail rotor then re-instal after you put in into the fuse. Darn good point now that I realy look at it. This should be interesting.
Old 02-19-2010, 07:08 AM   #640 (permalink)
problem is I have removed the tail rotor without dissasembling the tail assembly, wich would work except for the tail rotor shaft stickin out.
