450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
08-25-2009, 04:39 PM | #221 (permalink) |
actually it looks like the 450 sport does have a belt..... no pulley though!
08-27-2009, 01:58 PM | #222 (permalink) |
Haaaaaaaaaalelujah!!!!! Lemme get an Amen...
Spektrum DX6i, TRex 450SE V2 black , Scorpion 2221-8, Heliartist N23CP Hughes500D TRex 450SE V2 silver, Scorpion 2216-12, w/Spidergear, DarthDark Hughes300C, Blade MCX, HK-450, Cessna 182 foamie, 2 AR6100 -------------------------------- If it ain't broke, fly it... |
09-19-2009, 04:24 PM | #223 (permalink) |
i've just read this....
i've just resurrected my 450 XL - still using the plastic tail case tho.... should i take the pulley as well? wont the little stubs in the plastic case catch the belt? |
09-19-2009, 07:28 PM | #224 (permalink) |
assuming that the stubbs are the same as on the SE, no they shouldn't catch, if in doubt try it out... take the pulley out and the main blades off, then slowly wind it up, as long as you got correct belt tension they shouldn't interact... good luck
09-21-2009, 03:02 AM | #225 (permalink) |
"i've just resurrected my 450 XL - still using the plastic tail case tho.... should i take the pulley as well? wont the little stubs in the plastic case catch the belt?"
I have a 450XL with no pulley and a plastic case. When I first removed the pulley, I took the time to cut off the little stubs to make sure there was no chance of it rubbing. Now I just leave the stubs there and haven't had any problems with rubbing. |
09-22-2009, 09:22 AM | #226 (permalink) |
^^ hey thanks for that!
i do have the metal tail case but there's play in there so i've decided not to use it (was a cheap thing from hong kong thru ebay) i've just been going thru the heli and have found a slight (tiny tiny) bend in my main shaft so have replaced it. |
09-23-2009, 08:18 PM | #227 (permalink) |
How much past 200 mph do I need to go you ask? |
11-11-2009, 01:27 PM | #228 (permalink) |
I've had no problems, but what problems should I look out for?
11-17-2009, 10:39 PM | #229 (permalink) |
hey tomrex: do those ball links you added to the tail fin grips help? what effect does that provide? thanks ~ Langs
11-18-2009, 01:35 AM | #230 (permalink) |
They're a gyroscopic stabilization device nicknamed the "Chinese Weight Mod." It's been proven to reduce the stress on your tail servo significantly. That adds performance because your servo can now act closer to its fullest potential....and longevity because you're not taxing the servo nearly as much. Do a couple of searches and it should be plastered everywhere.
12-15-2009, 07:14 AM | #231 (permalink) | |
Why ist this weight mod called Chinese ? Don
TRex 500 ESP several hybrid 450s with bits from Align 450SEV2, CopterX, BEAM E4 and Outrage G5 Walkera 4G3 dbl BL |
12-15-2009, 08:00 AM | #232 (permalink) |
Haha....now you have me stumped!!!
03-20-2010, 10:40 PM | #233 (permalink) |
Another vote for the pully pull. Solved my belt tracking problems on the SE 100%, knock on atmospheric gases...
N1QVE Trex 450SE 'Calvin' Trex 450SE 'Hobbes' Trex 500 ESP 7CHP and DX7 Tx |
04-13-2010, 08:57 AM | #235 (permalink) |
can someone show a pic of the idle pully?
04-13-2010, 10:45 AM | #236 (permalink) |
It was not included with the SPORT model, FYI ...
... if your worried about that, don't you don't have it. Yours is the Sport model right? As for a picture I can't help you as most if not all of us that know have removed the thing out of hand. |
04-15-2010, 07:58 AM | #238 (permalink) |
trex450 se v2 just got it perfect tension and my belt broke ??? well started to see issues and thouhgt that is what happened-belt got off track and got wedged at tail! was going to removed it and spyed my blade 400 .its idler wheel is smaller and has sides! it popped in there perfect!8 flights no issues-i also used the belt off the blade 400! hope this helps and try checking your tension at the boom where the belt goes into the boom 3/4 deflection.
04-15-2010, 10:40 AM | #239 (permalink) |
Or just remove it !! Sorry bowmaaker, yup your suggestion for the Flanged Pulley has been suggested, discussed and beat to death three times over. Then paraded in the main forum discussed again and repeated another three times just in case anyone missed it. Repeated but yet again another three times, flogged again twice and beat with a BIG stick just to be SURE. Did I mention, did it forget to mention it was mentioned!?! YEAH using the Flanged Pulley as been suggested a just few of times over now and then some {LOL} PS: Welcome to teh Forums
